www.ColoradoClassicBroncos.com - View topic - broken front inner axle
It is currently Fri Nov 22, 2024 9:45 pm
Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
Post broken front inner axle
I made it to Conifer this afternoon, went out in the snow with my brother-in-law, and broke my left front inner and u joint. Anybody stock these in the Conifer/Denver area. Its supposed to be a D44?. Maybe stock? I am trying to get info from the po. I suppose if there is a place, I could pull it and take it in and figure it out. Any tips on pulling and re installing. This'll be my first attempt at axle work. Thank you. Russell
74. A few different shades of yellow, black, and rust. 80's 302 w/ edelbrock carb. 80's 4spd on the floor w/ dana 20 twin stick. dana 44 in front and full floating 31 spline ford 9" rear with a detroit locker. 4.56 gearing. 5 1/2" of lift w/ 35" general grabbers.
Mon Apr 18, 2016 10:07 pm
Post Re: broken front inner axle
I may have spare. The swap is fairly easy and is well documented. I'm writing this while taking off on a plane to San Bernardino, but can look this weekend.
Mon Apr 18, 2016 10:17 pm
That is a D44. You can use the short side axle from several donors and get a larger u-joint.
Tue Apr 19, 2016 12:48 am
While you're at it, order the Spicer 760x joint.
I wasted two sets of axles when my parts store HD u-joint broke and took out the shafts.
No issuses since installing the Spicer joint.
Build Thread:
Tue Apr 19, 2016 6:34 am
Alright. Great info! Thank yall! Ill do some more reseachin.
Tue Apr 19, 2016 7:10 am
Images: 2
Swapping the axles is very straightforward. I am a total rookie and replacing the u-joints in the D30 on my rig was one of the first things I did. There are some great youtube videos out there along with documentation if you like to follow along to those. That's what I did.
I used when I did mine. Obviously things might differ slightly from truck to truck but the overall procedure is the same.
Sally
'66 Halfcab
Tue Apr 19, 2016 9:28 am
Note that the axle seals on the D44 are just outside the pumpkin and can tear pretty easily. So just be careful when guiding the shaft back in. Replacing those seals requires you to pull the diff gears!
Tue Apr 19, 2016 9:56 am
Thank you Colby. Seems doable. Now I just gotta find the parts.
Tue Apr 19, 2016 10:25 am
Tue Apr 19, 2016 10:26 am
Images: 2
I lightly greased the diff side of the axle to try to get it to slide in without tearing the seal. Worked pretty well.
Sally
'66 Halfcab
Tue Apr 19, 2016 10:28 am
Viperwolf, Digger.
Is there a local (Denver/Conifer) store that has the parts, that yall like to use? Donor vehicle axles and the 760 spicer joint? Or am I looking at having to pull the axles off a rig and online sources?
Justin thank you but I do not want to take your spare and I hope to have this fixed up before the weekend.
Tue Apr 19, 2016 11:19 am
Tue Apr 19, 2016 1:45 pm
Well the bendix brake caliper stumped me for a bit but I got it off and pulled everything apart. I came across several concerns though. The rubber gaskets where the axle butts up to the axle housing and to the wheel housing are shot. Hopefully i can pick them up easily at a local parts store. Inside the axle housing is a lot of junk. Clean it out somehow? Do I need to open and drain the differential too? New axle seals? Other concerns are noted with the photos. Any comments, suggestions, opinions would be greatly appreciated! This is the first time I have had anything like this apart. - Russell
P.S. Can I just clean, regrease, get new gaskets, put it back together and be fine? Time is a concern, I leave for SW CO on Thursday.
Thank you again!
Sat Apr 23, 2016 11:16 am
New seals should be available at most parts stores, as they're a common part. Same with new spindle bearings, although they'd need to be pressed in. I would do new wheel bearings. They're cheap, and a failure is a really big deal. The inner that has a bunch of play is normal, and is under tension once correctly torqued to spec by the spindle nuts. Don't sweat the differently shaped axle, as it's not a big deal. As long as you've got it apart you might as well replace everything.
Sat Apr 23, 2016 11:26 am
The junk in the axle tube isnt a big deal.
The ends of the housing are open (other than a dust shield) and so sometimes mud and water will get in there. If it looks greasy / oily then your axle seals (located in the diff housing where the axle enters the diff) may be worn to the point where it is leaking diff gear lube into the housing.
It might pay to make sure your diff vent tubes aren't blocked and that you still have sufficient gear lube in the diff.
Sat Apr 23, 2016 12:51 pm
Just don't push your axle through the junk in the bottom of the axle tube when installing it. It's kind of awkward, but you want to "float" your axle into the diff. You don't want to pick up a bunch of crap and push it into the diff.
Sat Apr 23, 2016 1:02 pm
I used a shop vac with a rubber hose duct taped on the end to get all the loose crap out of my axle tubes a few times.
Sat Apr 23, 2016 1:31 pm
Well this is a sigh of relief! Cravenbronco helped me out at the parts store with all my seals and bearings. Digging out the shop vac and warming up my floating skills.
Will I be able to cold chisel the bearing out and press/hammer it in with a similar fitting socket?
Ill be topping off both differentials when I am done with all of this. My right rear was leaking and I replaced that axle seal earlier this week. I just used a socket and hammer for that one. Hopefully it works.
Thank you much for all the input and advice!!!
Sat Apr 23, 2016 1:44 pm
Well I got it all in and rolling again. Thank you again for all the help!
Mon Apr 25, 2016 10:10 pm
But it appears the axle seals are leaking. I was afraid of this. The differential was pretty low when I went to top it off. So, I get to do it all again plus, sometime later.
Does anyone want the passenger side axle?
Tue Apr 26, 2016 10:25 am
Images: 2
I did the same thing. Tore the whole axle down to replace u-joints. Could've done the seals, but didn't and they are leaky. I regret nothing....but I feel your pain. icon biggin
Sally
'66 Halfcab
Tue Apr 26, 2016 12:43 pm
Don't sweat it. The oil level for the front end only really matters when it's in 4wd. Check it once in awhile and before you go 4 wheeling. Broncos don't leak, they mark their territory.
Tue Apr 26, 2016 7:19 pm
Thu Apr 28, 2016 12:06 pm
Thu Apr 28, 2016 12:09 pm
Images: 2
Sally
'66 Halfcab
Thu Apr 28, 2016 2:31 pm
Fri Apr 29, 2016 8:24 am
Fri Apr 29, 2016 9:33 am
Fri Apr 29, 2016 9:34 am
Fri Apr 29, 2016 12:11 pm
Is this a leaky front seal Thread? Im not sure ive owned a bronco that did leak from one orifice or another & yes my front seals are currently leaking as well, but motivation is not present!
Fri Apr 29, 2016 2:09 pm
Users browsing this forum: No registered users and 48 guests
32,959,182 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
