It is currently Fri Nov 22, 2024 9:53 pm
[ 3 posts ] |
C4 valve bodies- some subtle differences
Mon Nov 14, 2016 8:24 pm |
Re: C4 valve bodies- some subtle differences
Mon Nov 14, 2016 8:25 pm |
The first one is a stock plate for '73-'75. The 2nd one is a stock plate for '76-'77. If you look at the lower right quadrant you can see the punchout identifiers on the edge of the plate. '70-'71 and '72 also had different plates.
Mon Nov 14, 2016 10:38 pm |
[ 3 posts ] |
Users browsing this forum: No registered users and 44 guests |
