csangster
Window Frame Adjustment help
So I have spent the past two years welding in new sheetmetal thorughout my bronco.
As I was fixing all the cancer, it became apparent to me that my bronco had been in previous accidents because the inner fenders were crumpled, the driver quarterpanel was bowed in (with bondo covering the carnage) and looks like it may have gently rolled over or ran into something on the top because the window frames are not straight (they have been massaged back into place by a previous owner).
Specifically on my passenger side door, the door fits well in the opening but the window frame interferes with the hard top.
Has anyone ever had to adjust the windowframe only? Mine are welded on (not bolted).
I am considering just cutting the corners to tweak it over and then re-weld in the new location.
Thoughts?
Chris
Thu Dec 01, 2016 10:54 am |
Re: Window Frame Adjustment help
Posting a few pictures may help others visualize the problem.
Thu Dec 01, 2016 11:58 am |
How is the gap between the bottom of the door and the rocker panel?
Thu Dec 01, 2016 10:10 pm |
rt9
Place a spacer between the floor board and the body mount. Firewall is sagging?
Thu Dec 01, 2016 10:37 pm |
Definitely post up some pics. Without pictures, I think we are all just guessing.
Fri Dec 02, 2016 7:33 am |
csangster
Fri Dec 02, 2016 10:54 am |
csangster
How does one attach photos?
Fri Dec 02, 2016 11:15 am |
plumbdoctor
rt9 might be on to something....do you still have original body mounts? The old mounts can cause issues
Fri Dec 02, 2016 12:34 pm |
csangster
Rt9,
Apologies, I didn't mean to be so dismissive. Things aren't exactly square, but that is due to all the repair guesswork I had to perform because of PO scab work
I'll take a look
Thanks Chris
Mon Dec 05, 2016 10:52 pm |
rt9
Tue Dec 06, 2016 11:17 pm |
