www.ColoradoClassicBroncos.com - View topic - 351w conversion oil pan?
It is currently Fri Nov 22, 2024 5:09 pm
Reply to topic  [ 8 posts ]
Post 351w conversion oil pan?
I was cleaning up parts when I noticed that my 351 pan out of the f250 is rusted badly. What is the best pan to use? I have seen the ones from WH and Duff. Are those the best way to go? I also found this from jegs. It looks very similar to the WH and Duff setups.
http://www.jegs.com/i/Ford-Performance/ ... 8/10002/-1
What is everyone else running?
TJ
F. Scott Fitzgerald
Tue Apr 25, 2017 3:50 pm
Post Re: 351w conversion oil pan?
That's the pan I have. The only complaint thing I have had any issue with was the Bronco Hut exhaust wouldn't fit without modification because the crossover pipe for that kit was designed to tuck up behind the stock 302 pan. Other than that, it's a nice pan.
Tue Apr 25, 2017 3:53 pm
I a man using pan from 96 Bronco with 351.
You can get it from Orielly's for like 70 bucks.
Requires a little love tap to one corner for clearance to front axle.
Tue Apr 25, 2017 8:52 pm
I've got a spare brand new 351 oil pan from a 1991 Crown vic. I have $50 into it. Won't fit my application for some reason (not deep enough), but perhaps I could take some measurements if you are interested.
If not, check rockauto.com for replacement pans. Some pretty good deals there.
Thu Apr 27, 2017 11:06 am
I ordered that kit from jets already. Thanks for the offer though.
TJ
F. Scott Fitzgerald
Fri Apr 28, 2017 10:41 am
Fri Apr 28, 2017 10:52 am
Fri Apr 28, 2017 12:23 pm
Thanks for the info. I have Manuel disc right now, but someday I'll upgrade.
TJ
F. Scott Fitzgerald
Fri Apr 28, 2017 5:17 pm
Users browsing this forum: No registered users and 31 guests
32,954,034 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
