Register •
FAQ
• Login
It is currently Fri Nov 22, 2024 12:04 pm
[ 5 posts ] |
ZF question
For those of you who have done ZF5 swaps, what are you using for a clutch pushrod into the master cylinder?
Tue Nov 21, 2017 1:19 pm |
Re: ZF question
I just ordered this: https://bcbroncos.com/shop/drivetrain/c ... ly-bronco/I know Chris made his own with some threaded rods and turnbuckle type stuff but at the end of the day, $25 wasn't much more than it would have cost me in materials and time. Also-- if you order that, you may want to order the ZF reverse light pigtail if you are going to hook that up.
Tue Nov 21, 2017 2:56 pm |
Re: ZF question
I cut off the push rod then threaded it. Used a turnbuckle and threaded rod with heim on the pedal side
Tue Nov 21, 2017 4:46 pm |
rooster
Joined: Thu Feb 12, 2015 8:29 pm Posts: 176 Images: 0 Location: Platteville
Re: ZF question
I did the same thing as landshark , but be careful not to put your hole on the clutch pedal too low like i did because then you have a pedal that's a little too firm...
Tue Nov 21, 2017 7:01 pm |
Re: ZF question
Also I am using a brake pedal and existing stud on the pedal.
Tue Nov 21, 2017 9:39 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 26 guests |
