www.ColoradoClassicBroncos.com - View topic - 435 gear shifter
It is currently Fri Nov 22, 2024 12:02 pm
Reply to topic  [ 17 posts ]
 435 gear shifter
Post 435 gear shifter
Was wondering if anyone was running this of type of shifter in there bronco? How do you like it ? Is it better that the stock ?
I was thinking of fabricating my own. This spring I'm going to be installing my new to me Np435. So I'm looking to see if anyone can give me some measurements on a few things. Such as the mounting bracket that the shifter mounts to. WxLxH. The triangles and the length of the linkage ( just length ) running from one side to the other. Length of the shifter it's self not including the heim joint.
Thanks in advance
Thu Jan 25, 2018 9:51 pm
Post Re: 435 gear shifter
I’ll look tomorrow and get you some measurements.
Thu Jan 25, 2018 11:08 pm
I had one... loved it. Seemed to shorten the shifting throw and put the shifter in a comfortable position.
Fri Jan 26, 2018 7:46 am
The higher the connection is on the faux shifter, the shorter the throw will be. If the distance between the pivot points and the other connection on both shafts is the same, then it should shift the same as if you were shifting the tranny stock. Fun project!
Fri Jan 26, 2018 8:59 am
Fri Jan 26, 2018 9:38 am
Alright I've got most of it fabricated up except for the linkage that hooks the shifter to the trans and the height of the shifter mount. Is there anyway someone can take a couple of measurements for me ?
Tue Jan 30, 2018 6:51 pm
Tue Jan 30, 2018 7:50 pm
Tue Jan 30, 2018 8:34 pm
Tue Jan 30, 2018 9:13 pm
Awesome thank you.
Last one is from floor to shifter knob.
Tue Jan 30, 2018 9:34 pm
Tue Jan 30, 2018 10:18 pm
Wed Jan 31, 2018 12:03 am
Wed Jan 31, 2018 6:45 pm
I've gotten a bit further on this project. It still needs a couple of adjustments. Besides that it looks good and seems like it should function. All that I have left is the mounting base and shifter. Hopefully I will get it all cut out and welded up in the next week or so.
Sat Feb 10, 2018 12:55 pm
Well I got the shifter rod welded. Also got the shifter knob and heim joint on and painted
Mon Feb 12, 2018 8:21 am
All that's left is the base plate.
Sun Feb 18, 2018 6:47 pm
Sun Feb 18, 2018 6:57 pm
Users browsing this forum: No registered users and 26 guests
32,949,839 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
