It is currently Fri Nov 22, 2024 6:01 am
[ 13 posts ] |
Power steering hose?
Looking to buy the closest High Pressure hose that will attach from my Explorer power steering pump ('01) down to my 4x4x2 box. Any specific part numbers and pieces appreciated!
I'm not looking to make my own if I can help it. ....also not looking to buy a $75 dollar hose + shipping from Bronco Vendor! sorry
Fri Aug 10, 2018 1:24 pm |
pgilbeau
Re: Power steering hose?
I don't know anyone that makes the specific hose. When I originally set up my hydroboost I had hoses made at the Parker Store. I know they have the fitting for the 4x4x2 box and should have the fitting for the Explorer pump. If there is one near you maybe check them out.
Fri Aug 10, 2018 9:01 pm |
I always make my hoses from stainless covered teflon and AN fittings. You will need an adapter for the pump from Wild Horses.
Sat Aug 11, 2018 4:28 pm |
Sat Aug 11, 2018 9:13 pm |
Sun Aug 12, 2018 9:51 am |
You’ll need length, hose diameter (likely 3/8), end angles like straight, 45 or 90, and then fitting size, most of us use AN-6 sometimes called JIC-6. The end angles will need to be lined up as most high pressure hose will not allow a twist in the line over a short distance.
Sun Aug 12, 2018 11:01 am |
This is the fitting for the pump. https://www.wildhorses4x4.com/product/F ... wer_O-RingFittings sizes for the 4x4x2 box are on this diagram. You'll need to figure what angle fittings & hose length will work between the pump & box, this one shows saginaw pump, Superduty h-boost, and cooler in the mix. hydroboostdiagram2_zps0e630afc.jpg anfittingsdirect.com is good stuff & quick to ship.
Sun Aug 12, 2018 11:26 am |
I appreciate everybody’s help and as you can see, I obviously have zero knowledge about fittings!!!!!!!!!
OK, let’s pretend I’m ordering...
I need a (-6 X 16MM X 1.5 LOWER O-RING adapter from Wild Horses) and for my hose I need a Female -6AN with a 90° bend from the power steering pump with 27” of 3/8” HP hose into a 45° angle into the PS gear with a Fenale -6AN and a 1/2-20” to -6AN adapter?
Am I close?
Sun Aug 12, 2018 12:34 pm |
That make sense to me. From what I've read, source your hose & hose fittings from the same manufacturer. There is some variance of hoses/fittings between brands. So if you use the fittings below from andirect, use their hose, not aeroquip hose. The WH fitting at the pump, and aeroquip fitting at the box are fine. http://www.anfittingsdirect.com/an-fitt ... a96214914chttp://www.anfittingsdirect.com/an-fitt ... a96214914chttps://www.summitracing.com/parts/aer-fbm2963Also, I read DO NOT use aluminum fittings on high pressure PS lines, they will crack under the pressure. Stick with steel.
Sun Aug 12, 2018 12:48 pm |
cpldavis37
BC Broncos will make you a line with the correct fittings. Just call them and tell them what you have. They made mine and they are nice.
Mon Aug 13, 2018 11:15 am |
cpldavis37
I don't think you can buy one for less then $70 dollars anywhere. Stock lines can be that much.
Mon Aug 13, 2018 11:18 am |
Mon Aug 13, 2018 11:52 am |
Getting closer...
2 AN fittings and the adapter fot the 4x4x2 PS Gear
Thu Aug 16, 2018 12:49 pm |
[ 13 posts ] |
Users browsing this forum: No registered users and 21 guests |
