Register •
FAQ
• Login
It is currently Fri Nov 22, 2024 12:44 am
[ 3 posts ] |
Engine gurus - Good brand of (neutral balance) flywheel?
Hey guys, I need a neutrally-balanced (sometimes called internally balanced) flywheel for a 302/351W.
What brands / vendors should I be looking at? Flywheel size is 164 tooth for 11" clutch, fitting a ZF5 transmission.
Mon Dec 03, 2018 8:00 pm |
sykanr0ng
Re: Engine gurus - Good brand of (neutral balance) flywheel?
The flywheel for the 300 I6 is the same size, same crank bolt pattern and zero imbalance. Is OEM acceptable? I do not have one for sale, have seen them often for reasonable prices.
Tue Dec 04, 2018 7:55 am |
Tue Dec 04, 2018 9:40 am |
[ 3 posts ] |
Users browsing this forum: No registered users and 12 guests |
