www.ColoradoClassicBroncos.com - View topic - Engine parts and Bronco parts
It is currently Thu Nov 21, 2024 10:16 am
Reply to topic  [ 1 post ]
Post Engine parts and Bronco parts
Thought I'd put these up here for a week before posting on CL or ebay. All items are OBO
GT40 heads (3 bar) with fresh professional valve job $500
1996 Explorer 5.0 short block (used, I was told it had 164k miles) with oil pan and cam and lifters. No timing cover. I can measure bores, believe they do not need to be bored. $200
Parts from 1994/95 Mustang 5.0 (SN95). This appears to be a low-mileage engine in nice shape.
- Used heads $100/pr
- Used crankshaft (I can measure, but expect it to be std/std) $75
- Used bare block (1 water pump hole had broken stud, drilled out, needs Heli coil). I can measure bores and expect them to not need boring. $100
- Short front dress (similar dims to Explorer) Timing cover, balancer, Alt bkt, PS/AC bkt, alt w/o pulley, PS pump, AC pump $200
- oil pan (dual sump) $40
- Upper and lower intake manifold $100
- Fuel rails and 19# injectors $50
- Throttle body, MAF $50
- GT cam and hydraulic roller lifters $100
- Used connecting rods and pistons $50
Several Explorer 5.0 upper and lower intake manifolds, with and without internal EGR $50 ea for uppers, $50 ea for lowers
Explorer 5.0 19# injectors $30/set, and fuel rails $10 ea
Explorer 5.0 throttle bodies $20, intake elbows $20, MAFs $20
351W Ford Racing connecting rod set (new in box). I believe these are made by Scat for Ford. Also works for 393 stroker. Bushed for floating piston pins. $290
Parts from 1994 5.8L 351W truck engine
- 351W used heads $50/pr (each one has a broken intake manifold bolt that needs to be removed)
- Used crankshaft std/std $100
- Used connecting rods and pistons $75
Misc flywheels and flex plates
Other Bronco/Mustang parts
- Generic small block 289/302/351W chrome valve covers (new) $40
- OEM 1970s Bronco power steering pump, bracket, cooler, and lower steering shaft $100
- 7 blade fan $45
I can send photos.
Gary
303-578-8432 Call or text
I live in Mead, about 2 miles off I-25
1966 Bronco. 351W with Explorer fuel injection, Cage 3.5" lift w/long arms, 2" body lift, NV4500, 4.56 ARB front D44/Detroit Locker 9" rear, 35" MTRs, hydroboost brakes and 4 wheel disks.
Sun May 19, 2019 7:24 pm
Users browsing this forum: No registered users and 11 guests
32,915,322 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
