www.ColoradoClassicBroncos.com - View topic - 9" and Dana 44
It is currently Sat Nov 23, 2024 3:09 am
Reply to topic  [ 1 post ]
 9" and Dana 44
Post 9" and Dana 44
I have for sale a 9", 28 spline, 4.11 with a Detroit in it. it's set up with 78 Lincoln disc brakes and includes the e brake cables. The shock mounts face forward on it. I just pulled it out of my Bronco to go with a 31 spline set up with Explorer brakes. The brakes on this need to be freshened up and probably the back lash on the r & p re adjusted. It didn't make any noises or have any issues other than the rotors need to be turned and I had the new axle ready to go in.
The 44 has a nearly new ARB and Dana 4.09 gear set in it. It was used only a short time before the Bronco was totaled in a roll over. The wear pattern is a tad high on the ring gear but worked well when it was in use. I have the compressor and most of the lines for it and will include it with the axle. It's for sale with out the shafts and brakes but I do have some stock shafts and d/b parts offered additionally if desired. A lot of people want to go new with these parts.
I'll take $1,500 for the pair or $800 individually. Don
Wed May 22, 2013 11:14 pm
Users browsing this forum: Google [Bot] and 2 guests
32,965,363 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
