www.ColoradoClassicBroncos.com - View topic - Old stock engine parts
It is currently Fri Nov 22, 2024 3:05 am
Reply to topic  [ 1 post ]
Images: 14
Post Old stock engine parts
I have an old stock radiator in good shape with no leaks, for a manual transmission.
SOLD - Harmonic Balancer, Damper.
SOLD - 2bbl carb
Original iron 2bbl intake with and 1" spacer.
Timing chain. Tight, no slack.
Timing chain cover. 1 of the 2 fuel pump holes needs to be re-threaded, it's stripped.
1 single groove water pump/fan pulley
1 single groove crankshaft pulley / 3 bolt
Original exhaust manifold from a 302. ***One of the holes that attaches to the block has a crack clean through!*** (full disclosure :) ...you can actually see it in the picture 3rd from the left.
I have some old headers that I bought before I picked up Justin's fire breathing setup that I was told came off a '74 Bronco.
Front stock brake line, rubber with brass ends, the middle one from the frame to the pumpkin, before it goes out to Rt/Lt front brakes.
SOLD - stock bumper hitch
Make me an offer! Don't be shy :)
Thanks,
Mike
Sun Mar 30, 2014 10:57 pm
Users browsing this forum: No registered users and 25 guests
32,940,132 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
