It is currently Fri Nov 22, 2024 7:12 pm
[ 15 posts ] |
Cooling fans. Coolers. Bronco starter new high torque auto
trei75bronco
husky 268 pc tool kit in case $75 Hayden cooling fan $30 Hayden cooler 516 model $35 Summit fan sum g4902 Single, 12 in. Diameter, Reversible, 1,107 cfm $50 Derale 13504 plate fin cooler 11x11. $ 50 14" 95lb springs 2.5" coil over. $40 Dana 60 5 lug brake brackets and spacers ford spindle. $40 Cargo plane tie downs $30 Brand new high torque stater for auto ford 302-351 $75
Sat Apr 11, 2015 10:13 pm |
Re: Cooling fans. Coolers. Bronco starter new high torque au
Interested in the tie downs. How long are they?
Sat Apr 11, 2015 11:14 pm |
I'll take the tool set assuming it is complete
Sun Apr 12, 2015 1:17 am |
trei75bronco
Tool set is complete
The tie downs are about 40" long each
4781 s riveria at Centennial co 80015.
Be in the garage all day
Sun Apr 12, 2015 6:12 am |
Sun Apr 12, 2015 9:01 am |
Sun Apr 12, 2015 9:25 am |
trei75bronco
That's fine
Sun Apr 12, 2015 11:07 am |
trei75bronco
Mon Apr 13, 2015 7:38 pm |
sykanr0ng
Is any of this stuff still for sale?
I see it all still up on CL too.
Fri May 08, 2015 5:46 pm |
valentino
any chance those brake brakets will fit on a ford 9
Fri May 08, 2015 9:27 pm |
trei75bronco
Yes I have the rear leaf spring brackets Cooling fan Brackets
No those brackets will not fit a 9"
Diy4x has a bracket use montecarlo calipers and Suzuki sidekick 4 dr rotors
Sat May 09, 2015 8:02 am |
Moab Mike
What do you want for the rear leaf brackets?
Sat May 09, 2015 1:31 pm |
trei75bronco
For all 4 100 dollars
Sat May 09, 2015 9:58 pm |
Moab Mike
Sun May 10, 2015 7:22 am |
trei75bronco
Sure is
Sun May 10, 2015 5:48 pm |
[ 15 posts ] |
Users browsing this forum: No registered users and 52 guests |
