www.ColoradoClassicBroncos.com - View topic - Bilstein 7100 14" short bodies
It is currently Fri Nov 22, 2024 2:16 pm
Reply to topic  [ 8 posts ]
Post Bilstein 7100 14" short bodies
I'm guessing someone around here needs these. Especially if you're running a heavy engine. Not mine.
http://www.pirate4x4.com/forum/axles-ti ... x-4-a.html
Thu Jun 25, 2015 9:23 pm
Post Re: Bilstein 7100 14" short bodies
I started researching shock options earlier this week but ran out of time.
I imagine these require mods such as shock hoops, etc ?
Fri Jun 26, 2015 6:16 am
Great shocks, but you are going to have to find room, very long. F250 mounts, hoops, etc. I'd think you'd need long arms to use all the available shock.
Fri Jun 26, 2015 7:50 am
x2. F-250 mounts at a minimum, something longer like hoops or fabricated mounts is even better. They're pretty much the idea setup for a rig that will see any meaningful off roading. They're also easy to rebuild and revalve, so you get some flexibility in setup. These are valved a little heavily for a Bronco-the norm for front use would be 360/80.
Fri Jun 26, 2015 9:48 am
Justin, do you know if the valves are interchangeable between these shock and the pair I bought from you? If so then I should have a set that may work.
Fri Jun 26, 2015 10:25 am
As far as I know all of the 7100 shocks have interchangeable shim stacks.
Fri Jun 26, 2015 2:44 pm
all the 7100 valve stacks are interchangeable. What do you need? i have a bunch of valves here.
If you do not have long arms you need to run the 12" 7100's
Fri Jun 26, 2015 3:47 pm
Build Thread:
Sat Jun 27, 2015 12:19 am
Users browsing this forum: No registered users and 48 guests
32,951,732 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
