www.ColoradoClassicBroncos.com - View topic - WARN 6014 (Pre 8274) Winch - $350 OBO
It is currently Sun Nov 24, 2024 9:35 am
Reply to topic  [ 2 posts ]
Post WARN 6014 (Pre 8274) Winch - $350 OBO
This is a WARN 8274 type winch which came out after the 8200 and before the 8274. It has the Bellview case but warn internals, includes power out and in and I believe free spool. I pulled the case apart, cleaned the internals, resealed and filled it. Have used it 2-3 times but moved on to another winch since. I have two different sets of cables - no idea on length. I also have two sets of that you solenoids and cases, including a hand control to spool in and out.
Everything works perfectly, again I have used this winch a few times, have pulled a 6000 lb truck upright and pulled myself out of a mud hole once - probably in excess of 8000 lbs on that pull.
According to the stampings on the top of the case the Winch was probably made in September of 1973, the 8274 was introduced in 1974. This Winch was originally installed at a Ford Dealer on an early bronco sometime in 1976 and I removed it from the original winch bumper several years ago.
Asking $350 or best offer.
Tue Jun 20, 2017 3:30 pm
Post Re: WARN 6014 (Pre 8274) Winch - $350 OBO
SOLD!
Fri Jul 21, 2017 10:44 am
32,995,751 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
