www.ColoradoClassicBroncos.com - View topic - Premier power welder - Gone!
It is currently Thu Nov 21, 2024 9:41 pm
Reply to topic  [ 10 posts ]
Post Premier power welder - Gone!
The system was installed before I purchased my bronco. I've had it 4 years and haven't used it, finally my alternator died. I called premier for replacement my specific alternator was discontinued. An updated alternator could of been had but decided to install a regular 140a. Since I never used The system I mostly just camp and daily my truck. The alternator was a gm 12si style anyway.
1 premier power welder system
1 extra regulator
1 set stick weld leads (power/ground)
1 set bypass harness
1 vernier idle control
Minus the alternator
Everything I listed is here in the link including prices
http://premierpowerwelder.com/shop/parts-accessories/
Not interested in retail price for any parts clearly it's a used system, just giving ballpark. Plus an alternator will need to be purchased from premier to make the system work. The whole system is the same just changes alternators. I'll make a deal.
Make offer or..
Will trade, bronco parts (grille, front fenders, doors..anything)
Metal fab tools. Jd2 model 32 dies shop press
Anything cool... whatever you think it's worth to ya.
Can meet, or bring to a Colorado springs breakfast meet.
I drive to Denver everyday for work i25 and colfax.
Let me know!
1996 bronco 4bt sas .
1972 bronco 10k mi no motor no trans..unfortunately rolled in 1973. Left for me to bring back from the dead.
Sat Feb 24, 2018 7:40 pm
Post Re: Premier power welder
I’m interested and I’d like to look at the system and check out what alternator I’d need to source to work with my 4BT. I could meet off of I-25 & Lincoln or Ridge Gate at a time that works for you.
Sat Feb 24, 2018 8:01 pm
Ok cool, the truck this was in has a 4bt. It was in my full-size 96. I still have the original premier alternator just have to call them to get the new version if you have the same brackets. I swapped in a acdelco 140a cs144.
Sat Feb 24, 2018 8:25 pm
I could probably meet up 6-630 after work Monday at the cabellas, on ridgegate in lone tree
Sat Feb 24, 2018 8:33 pm
Sat Feb 24, 2018 8:56 pm
Sun Feb 25, 2018 9:24 am
Premiers welders are 180amps ish depending on configurations, where they're different is when welder is kicked on it full fields and makes 72v+ I have your pm ill be in contact with ya!
Sun Feb 25, 2018 2:39 pm
I know a guy that could likely get that alternator fixed right up. He's the one that built my 200amp explorer alternator.
Sun Feb 25, 2018 7:44 pm
Sun Feb 25, 2018 8:09 pm
http://j2fabrication.com/
Give him a call and ask. He might be able to do something for ya.
Sun Feb 25, 2018 8:24 pm
Users browsing this forum: No registered users and 25 guests
32,932,874 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
