www.ColoradoClassicBroncos.com - View topic - Crawler parts for sale!
It is currently Thu Nov 21, 2024 8:35 pm
Reply to topic  [ 12 posts ]
Post Crawler parts for sale!
Help me recover from my 60-9 build and install by buying my old stuff for a good price!
First up. My old Dana 44. It is complete from hub to hub. Loaded with chromoly axles and Yukon super joints, 5.13 gears, full Yukon spool, riddled diff cover and Ford disc brakes. Came out running and driving with good ball joints, brake pads and wheel bearings. Warn premium hubs. This axle is great for a bronco that's lifted 4.5" or higher. I've cut and rotated the Cs at the end of the housing to gain caster. It was setup so I had 8° of caster with 5" of lift on extended radius arms. It also allowed me to use the stock driveshaft with no binding. It has a track bar riser on it with tabs for ram assist.
SOLD!
4x4x2 steering gearbox. Tapped for ram assist. Can be used without ram assist with the caps installed over the ports. It is tight and leak free with about 1500 miles on it since converting and resealing. Comes with a heavy duty drop pitman arm that's drilled out to 3/4" for heim jointed drag link.
Sold!
Drag link and tie rod. Heim jointed. Drag link goes to passenger side knuckle and is stacked on the tie rod over the knuckle. Drag link is 1.5" o.d. .250 wall and the tie rod is 1.75 o.d. . 375 wall Dom. Heim joints are all tight except for the pitman arm end. I'll throw in a good one there. Fits Ford knuckles.
Sold.
Steering assist ram. 2"x8" trail gear ram. Only about 1500 miles on it. No leaks. No play in the rod ends. Good shape and powerful.
Sold!
36x13.50x15 Iroks and beadlocks. Decent shape still. A couple a little more worn than the other 2 but not bad. 8/32nds of tread on the lowest 2. Bead locks are old Rockstomper 32 bolt bead locks. Recessed bolts to avoid rocks. Good shape with no major bends. All hold air with no plugs or patches. Hook up really well to the rocks.
SOLD!
Extended and wristed radius arms. Extended about 10" and have a bend in them for tire clearance. Could use some fresh paint.
Sold
Package deals encouraged and appreciated! If my prices seem high please don't be afraid to say so! I really have no idea what to ask. I'll be posting on the national site as well as Craigslist.
ALL SOLD! THANK YOU!
Last edited by crawlercreations on Fri Mar 23, 2018 7:55 am, edited 3 times in total.
Mon Feb 26, 2018 4:41 pm
Post Re: Crawler parts for sale!
Cage coils as well. Supposed to be 5.5" of lift. Gave me about 5". Really flexy and good riding. Paint is rubbed off in some places from the tires.
Sold
Last edited by crawlercreations on Thu Mar 01, 2018 2:09 pm, edited 1 time in total.
Mon Feb 26, 2018 4:44 pm
I think I’d like the 4x4x2 box & ram, are you including the hoses or did you reuse them on your current setup?
Mon Feb 26, 2018 6:38 pm
Interested in box if Kinder doesn't grab it.
Mon Feb 26, 2018 6:40 pm
Mon Feb 26, 2018 6:41 pm
Images: 14
Do you know if the axle is plug-n-play for us normal folk? If I'm swapping out my Dana 30 for your 44?
Is it regular width or wider?
Thanks
Tue Feb 27, 2018 10:33 am
Tue Feb 27, 2018 10:50 am
Images: 14
It's only lifted 3.5" ....But I've always wanted a 5.5" luber!!!
Tue Feb 27, 2018 1:35 pm
Tue Feb 27, 2018 2:22 pm
4x4x2 gearbox and ram are sold. Thanks Kirk!
Tue Feb 27, 2018 2:23 pm
Steering linkages are sold! Thanks Keith!
Coils and radius arms sold! Thanks Craigslist!
Only have the axle and tires for sale still. Lots of interest but no commitments yet. Someone might be coming from grand junction for both but he hasn't confirmed yet.
Thu Mar 01, 2018 2:11 pm
Users browsing this forum: No registered users and 25 guests
32,930,728 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
