www.ColoradoClassicBroncos.com - View topic - 302 heads with emissions 76 - 77
It is currently Sat Nov 23, 2024 10:29 am
Reply to topic  [ 13 posts ]
Post 302 heads with emissions 76 - 77
Well it turns out the heads on my engine are not emission heads. Engine was swapped at some point in the early 80's. Looking for a set of 302 heads with the air induction ports ideally from a 76 or 77. .
Looking to take my engine back to stock or close to it and looking to put the emissions back on.
Would be nice if they were in decent shape but don't have to perfect as I will have them rebuilt anyway. Let me know what you have and how much.
Sat Mar 03, 2012 9:35 am
Post Re: 302 heads with emissions 76 - 77
What heads do you have? Part number is on bottom near intake side. Do they not have the thermacter holes in the exhaust ports?
Sat Mar 03, 2012 9:49 am
Sat Mar 03, 2012 7:03 pm
I have a set of E7TE heads that I started smoothing out the ports on but never finished. Got tired of grinding and bought the AFR's. Free to good Bronco home.
Sat Mar 03, 2012 10:02 pm
I'm unfamiliar with the E7TE heads are they emission compatibile? i will take a look at the number on my head today - have to work this morning for a few hours.
Sun Mar 04, 2012 10:18 am
the e7te is the same as what is on your big bronco, and 5.0l mustang
Sun Mar 04, 2012 12:17 pm
OEM 77 EB (76 was the the same from what I've witnessed) 302 head/s have one emissions (air check valve) port located on the exhaust side at the right hand end (cyl #1 or #8). Rubber tubing is used to route piped air. The D??E casting numbered heads were among the last with the cast rail type rocker arm/s.
The E7TE heads have the emissions ports located on the ends of the head and use a threaded plug on one end of the head so that the ports are active on the firewall end of the head in most applications. Steel piping is used to route air to the ports again in most applications. Should be OK for emissions pass. They were used for trucks and 5.0 HO applications.
Sun Mar 04, 2012 2:04 pm
Yes i have all the emissions tubes for a 76, hence why i want to go back to a 76 stock head instead of whatever year i have, which is probably a 74 or 75 head not sure, returning the truck to stock config as much as possible.
I have picked up a single type emission tube for the rear heads type air injection as well.. and could make that work will have to see
Sun Mar 04, 2012 2:07 pm
Sun Mar 04, 2012 10:43 pm
Should be on the bottom near the pushrod holes.
Mon Mar 05, 2012 2:10 am
oh i have to take them off.. lol ok i will do that after i get the body back on the frame.. iam out of room right now.. 2 axles and about to coat the frame...
Mon Mar 05, 2012 2:22 am
I have a line on a set of 1975 heads with the emission ports. These should work I assume?
The guy is asking for an offer, plus shipping.. any ideas on what these are worth? i was thinking $80 + shipping?
Wed Mar 14, 2012 11:16 am
Bought em. 90 including the shipping.
Fri Mar 16, 2012 11:36 pm
Users browsing this forum: No registered users and 14 guests
32,972,042 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
