It is currently Fri Nov 22, 2024 8:41 am
[ 9 posts ] |
C4 Automatic Transmission Inspection Plate
75DBE
Anyone have one of these lying around? I must have had it at some point, but it seems to have disappeared from my garage -- along with my power steering pump! Grrr...
Mon Jul 09, 2012 2:13 pm |
Re: C4 Automatic Transmission Inspection Plate
They'll hide in the corners.
Mon Jul 09, 2012 3:21 pm |
I'll have one for you this week. I've also got your PS pump and new alternator.
Patience...
Mon Jul 09, 2012 7:03 pm |
75DBE
Ok, deep breath, deep breath. :-)
Tue Jul 10, 2012 7:34 am |
I'm jumping again today so might be tomorrow before I get everything dropped off.
Tue Jul 10, 2012 7:56 am |
Viper, any discernible differences between the C4 cooler lines across the years? I think 75DBE misplaced his after we pulled the motor and what not. Was planning to hit up the yard and maybe stock up.
Tue Jul 10, 2012 8:17 am |
Tue Jul 10, 2012 8:30 am |
Ugh. JBG. So, the bends in F series lines are probably going to be too crazy for a Bronco application huh?
Tue Jul 10, 2012 8:35 am |
Probably longer on the front and radiator ports are probably further to the right. You might be able to make it work.
Tue Jul 10, 2012 8:47 am |
[ 9 posts ] |
