www.ColoradoClassicBroncos.com - View topic - 28oz or 50oz Flywheel
It is currently Thu Nov 21, 2024 11:31 pm
Reply to topic  [ 9 posts ]
Post 28oz or 50oz Flywheel
I picked up a used 302 and am going to replace the clutch and flywheel before I put it in. I can't tell if the flywheel is a 28oz or 50oz? Anybody have any suggestions based off the pic? The engine block is a E0AE D3C, but I think it may have been rebuilt. Any help is greatly appreciated.
Mon Sep 21, 2020 7:35 pm
Post Re: 28oz or 50oz Flywheel
Or should I just get this one resurfaced and not bother buying a new one?
Mon Sep 21, 2020 8:05 pm
E0 is 1980
1968-80 302 engines were built with a 28-ounce imbalance factor. 1981-2001 302 engines were built with a 50-ounce imbalance factor.
Mon Sep 21, 2020 9:48 pm
If your not sure I would see what you can find online with the casting number for the block, E0 is 1980 which is around the time the 302/5.0 changed from 28oz to 50 oz imbalance. The casting number on the flywheel E8TR-AA is a 1988 casting number which if it was from a 302 would be the 50oz imbalance, however if it was from a 351W it would be a 28oz imbalance. I would try and find as much info as I can on those casting numbers or just have it resurfaced. I am sure someone else will chime in.
Mon Sep 21, 2020 9:54 pm
What does resurfacing do for you? A general question, not specific to this post?
Tue Sep 22, 2020 7:34 am
Tue Sep 22, 2020 9:32 am
And you can probably get the ring gear replaced by the machinist.
Tue Sep 22, 2020 10:53 am
I vote for resurface and starter gear as mentioned.
Owned my 1972 since 1985
Canon City, Co
Wed Sep 23, 2020 2:32 pm
I went the safe route and just got the flywheel resurfaced...
Wed Sep 23, 2020 7:35 pm
32,934,571 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
