It is currently Sun Nov 24, 2024 10:23 am
[ 15 posts ] |
pgilbeau
Pinion Guard Install
I haven't messed with my 9" center section except for putting it in and taking it out. I want to install a Ruff Stuff pinion guard but not sure if I can just pull the bolts and put the guard on or will I need to set the gears back up after pulling the bolts and installing the guard. https://www.ruffstuffspecialties.com/9F-PIN.html
Wed Oct 21, 2020 10:23 pm |
Re: Pinion Guard Install
No setup required. Might need longer bolts.
Thu Oct 22, 2020 9:17 am |
pgilbeau
Thu Oct 22, 2020 9:26 am |
confirmed, longer bolts are all that is needed
Thu Oct 22, 2020 11:05 am |
pgilbeau
Thu Oct 22, 2020 6:32 pm |
I installed the Duff version which is a nice piece
One thing I don’t like about any of these is that it makes using the center of the axle as a place to jack the axle up a bit unstable
Thu Oct 22, 2020 7:14 pm |
pgilbeau
Thu Oct 22, 2020 7:43 pm |
Check out the Currie skid/pinion one. Pretty nice.
Fri Oct 23, 2020 12:10 pm |
pgilbeau
Fri Oct 23, 2020 9:06 pm |
I think so, its the piece that bolts on. i know it fits the regular currie 9" as someone i know has one installed. To me its way too expensive - $240. The design seems like it would do a great job of protecting the the lip and bottom 3rd member better than anything else out there. Really its super simple and wouldn't be too bad to fabricate. I just decided to weld on some 1/4" plate to the bottom and back of the housing and used the Ruff Stuff Pinion guard.
I
Mon Oct 26, 2020 10:58 am |
pgilbeau
Mon Oct 26, 2020 6:00 pm |
Agreed - here are a couple of photos of what I did. I dont' have any of the bottom of the housing but its just 1/4" plate similar to the back bottom.
Tue Oct 27, 2020 9:21 am |
pgilbeau
Thanks for the pic, probably going to do something similar.
Thu Oct 29, 2020 4:47 pm |
Getting prepped to install the ruffstuff pinion guard at some point in the next while and was wondering about the bolt length. I did not order the bolts with the guard (didn't even think about it at that time). Can anyone confirm or recommend the bolts needed? From this thread it looks like longer ones are needed. Would rather get some at ACE than order from RuffStuff.
Fri Dec 03, 2021 4:07 pm |
I don't know the length offhand but you can get them at ACE no problem, thats what i did - assume 1/2" longer grade 8
Fri Dec 03, 2021 4:27 pm |
[ 15 posts ] |
Users browsing this forum: No registered users and 31 guests |
