www.ColoradoClassicBroncos.com - View topic - 72 restore/mild build
It is currently Thu Nov 21, 2024 1:19 pm
Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Re: 72 restore/mild build
Okay, finally had some time to work on the Bronco. Finished installing the quarters and cut outs for the flares and side marker lights. I also got all the bare metal etch primed.
So what's the next step? I plan on using all PPG products from here on. Should I:
1: epoxy prime
2: fill/block
3: surface prime
4: fill/block
5: paint
or
1: surface prime
2: fill/block
3: paint
My Personal Website -
Mon Mar 07, 2011 10:37 am
I am not the pro, but I ended up fill-priming 4 times. Once immediately after the Etch Primer. 2, 3, 4th times after block sanding. I was surpirsed how flat I thought it was, then would quickly find out after blocking that it was not flat. Each time I would get it closer and closer to the final product. I had it delivered to my paint pro and he stated that is was a good job but still doing ANOTHER primer and block sand on the hood.
Not to add another step, but my auto body guy is doing a sealer primer just before paint.
Mon Mar 07, 2011 10:52 am
May I make a suggestion on primer.I use a PPG industrial epoxy primer sealer(CRE catalyst CRE primer sealer)Il ike it #1 because its cheap,#2 its tintable #3 super hi build I think up to 30 mils.at a time#4 sands awsome and is super stable.
A mixable gallon is about a $100 bucks and goes a long way.avalible at painters supply.
P.S. theres some tips on mixing if you decide to go this way.Let me know and i'll fill you in.JGZ
Mon Mar 07, 2011 12:50 pm
Got the first coat of primer on today. Going to block tomorrow and try for a second but may have to wait until later this week. Looks pretty good but I definitely see some areas that need attention before another coat.
Wed Mar 30, 2011 6:48 pm
You have come a long ways man!! Don't skimp on the details now!
Thu Mar 31, 2011 9:31 am
Is that a fiberglass hood? Man oh man, you are moving forward with your project...Nice work!
74 Ranger
65 Fastback
Thu Mar 31, 2011 2:53 pm
Hood is fiberglass. Hit the gel coat with some 220 grit before primer. PO never had it painted so there was dirt and grim on it. It cleaned up nice though.
Fri Apr 01, 2011 4:30 pm
While I was waiting for the paint guy to show up yesterday to give me an estimate I started working on the my dash a little. Before I knew it I have the glovebox cut out and moved 3" to clear the rollbar. After work today I'm going to fill the rest of the holes and prep for the dash for paint.
Fri Apr 08, 2011 7:51 am
I have never seen someone just move the glove box over 3".
A friend of mine in TX had a bronco that the whole dash was shortened 3" either side and that allowed for the roll bar to tuck neatly between it and the door. If I ever do a new cage, I will probably go this route.
Thanks for the update!
Fri Apr 08, 2011 8:24 am
Thats how I roll! icon biggin
Make it fit!
Fri Apr 08, 2011 9:32 am
Where are you going to stash your speaker? Like its a huge worry! LOL...
74 Ranger
65 Fastback
Fri Apr 08, 2011 10:33 am
Music has pretty much been an afterthought. banghead
I've seen so many cool ways to mount speakers. I think the best was the speakers in the kick panel using a hotel pan. I may end up going this route.
Fri Apr 08, 2011 10:55 am
Maybe overhead in your cage?
Fri Apr 08, 2011 11:19 am
What is a Hotel Pan?
Fri Apr 08, 2011 11:20 am
Overhead in the back might be okay but I don't know about the front.
Hotel pans are those trays that line cooks use. Like what they use at subway to store all the veggies. I have no idea why they are called hotel pans.
http://www.google.com/search?q=hotel+pa ... 09&bih=807
Fri Apr 08, 2011 11:36 am
Sounds like a good idea to me! Maybe extend you dash down towords the floor and put them in front of the sticks...
74 Ranger
65 Fastback
Fri Apr 08, 2011 5:02 pm
You do really nice work. Good to see progress made at a regular pace with so many members on here. I was going to give you some pointers about the body work ( I used to do that stuff years back, went to school for it etc etc) but it looks like you figured it out.
I really like POR products. I coated my straight axle on my 64 F100 with it. looks brand new. I will more than likely use it on my floors in my EB as well. I also used some PPG Epoxy primer on my 69 Mustang before it was painted. Thats a neat product but I would hate to be the person that has to remove it next time. foshizzle
Fri Apr 08, 2011 8:39 pm
Sun Apr 10, 2011 10:06 pm
Sounds good to me...I think your only other option is white if you have plans on putting other colors on the inside.
74 Ranger
65 Fastback
Mon Apr 11, 2011 10:00 am
I would paint the dash to match the outside of the truck, door frames, door jambs, etc.
Mon Apr 11, 2011 10:33 am
Mon Apr 11, 2011 11:26 am
Are you doing a solid blue on the outside or incorporating any stripes? If doing stripes, I'd paint the dash to match the stripes.
Mon Apr 11, 2011 5:55 pm
Finally some progress to report icon biggin
Should be ready to pickup from the paint shop in a week and a half.
The garage feels so empty now.
Thu May 05, 2011 9:30 pm
Enjoy the time off from the project. I would use this time to make complete lists of what you need. I forgot a few things and paying shipping over and over is not fun. It is easy to remember the big stuff, but don't forget the little stuff like bolts, seals, weather stripping, lenses, mirrors, door hardware, wheel center caps, windshield seal, etc.
Towing is the best way - trying to get a non-running non-braking Bronco on a trailer would NOT be fun.
Looking forward to more pics! Keep us updated!
Thu May 05, 2011 10:09 pm
Was there some sort of contest that I missed here? Your truck looks like its going to be a real beauty...
74 Ranger
65 Fastback
Fri May 06, 2011 9:44 am
sounds like we should have take a vote at the June breakfast
winner gets free breakfast
Fri May 06, 2011 10:30 am
Secretly I've been competing with Entourage. Finally being able to attend a breakfast might be better than free breakfast.
Fri May 06, 2011 12:12 pm
Copy that...There could be catagories like mall crawler, rock crawler, daily driver, show pony you name it!
74 Ranger
65 Fastback
Fri May 06, 2011 5:54 pm
Okay, need a recommendation. I'm having the painter shoot bedliner too and I can't decide if I should have him shoot it over the bedrail. What is everyone else doing.
How far from the inside over the rail did you go? Thanks
Tue May 10, 2011 8:57 am
You want it for protection. In that case, I would have him stop where the bedrail begins to slope down to the quarter panel. What does your painter suggest?
Tue May 10, 2011 9:00 am
Users browsing this forum: No registered users and 15 guests
32,919,037 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
