www.ColoradoClassicBroncos.com - View topic - Sudden electrical wierdness
It is currently Fri Nov 22, 2024 12:25 am
Reply to topic  [ 12 posts ]
Post Sudden electrical wierdness
Suddenly my gas meter stopped working. My passenger tail light won’t turn off, my driver side brake light won’t work, unless I’ve turned my left turn signal on - that activates my drivers side brake light.
Any ideas?
Thu Mar 18, 2021 6:55 pm
Post Re: Sudden electrical wierdness
With any electrical weirdness, start making sure your grounds are good. I'd look at a wiring diagram and see what all those have in common as well. Might be the plug under the hood right in front of the driver came a bit loose?
Thu Mar 18, 2021 7:23 pm
The wiring harness going back along the frame has a problem. If you have exhaust running along the drivers side it's somewhat common to melt those wires.
Thu Mar 18, 2021 8:50 pm
I’ll add that since you just did a bunch of exhaust work you may have jarred the wires and made an almost problem a real problem. Look along the harness from the firewall back and see if the wrap (electrical tape likely) looks nicked or otherwise damaged and start there.
Fri Mar 19, 2021 5:53 pm
Here’s a video of the wiring along the frame. Not really sure what I’m looking for. Seems fine to me? https://youtu.be/3Xvg5lL3tgk
And here are some pics.
Mon Mar 22, 2021 2:05 pm
Good news. I cleaned the grounds at the brake lights and problem solved! But the fuel meter still nothing.
Mon Mar 22, 2021 5:20 pm
Mon Mar 22, 2021 6:06 pm
And fuel gauges only work in 30% of Broncos so don’t beat yourself up too much if it doesn’t work!!
Mon Mar 22, 2021 8:14 pm
Mon Mar 22, 2021 8:15 pm
Mon Mar 22, 2021 8:19 pm
Ha well that’s good to know. Did replacing the sending unit solve it for you?
Tue Mar 23, 2021 5:20 am
Tue Mar 23, 2021 9:34 am
32,935,529 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
