www.ColoradoClassicBroncos.com - View topic - EFI vapor lock....SOLVED!!!!
It is currently Fri Nov 22, 2024 2:02 am
Reply to topic  [ 56 posts ]  Go to page Previous  1, 2
Post Re: EFI vapor lock....maybe
Thu May 20, 2021 9:11 pm
Throw a new fuel filter at it, I had the same issue when I redid my fuel system. Actually did a quick little “delete” just to see if anything changed as I drove around the block. (Probably not smart so do at your own risk I suppose) Sure enough it ran perfect so I ordered a serviceable one right then so I can pull and clean it out wherever I am.
Thu May 20, 2021 10:15 pm
My set up is very similar to the pic Eck posted up.
Tank---NEW cheapo filter---LP pump----accumulator----HP pump---NEW filter---injectors---Return to accumulator---tank
32 psi and was at 22 psi an hour or so later
What's a quick little delete?
Eck-What post HP filter do you use?
Fri May 21, 2021 8:08 am
Bypass the filter for testing purposes is what I meant. If the filters are both new that shouldn’t be the issue then. What cheap filter are you using?
Fri May 21, 2021 8:13 am
https://www.amazon.com/FRAM-G3-In-Line- ... CEJ61BQS6V
Fri May 21, 2021 8:17 am
Good enough GPM and clear so you can see contamination probably rules that out.
You said you were EFI, do you have an fuel pressure regulator on the rail?
Fri May 21, 2021 8:25 am
Fri May 21, 2021 12:07 pm
I'm still having problems with sputtering and occasional backfire when accelerating or putting load on the engine (going up a hill). I tried going without the hp filter but that didn't change anything.
Primed and after the engine is off the psi is 40
Idle psi is 34
Before I go after the injectors is there a way to test the pressure regulator?
Sun May 23, 2021 2:32 pm
https://axleaddict.com/auto-repair/How- ... -Regulator
A new FPR is about $50 at O’Reilly’s.
Sun May 23, 2021 2:46 pm
FPR passed the tests. Thanks for the link.
Sun May 23, 2021 3:21 pm
Jog my memory, this is a stock tank with the factory pickup/sending unit right? You might consider pulling the pickup out and confirming the “sock” isn’t falling apart and plugging the pickup.
Wed May 26, 2021 6:59 am
Quick Update:
I pulled the upper intake and got to the injectors. I soaked, cleaned, tested, and blew them all out. I ordered a rebuild kit and put it all back together. No change. Idles fine but sputters on acceleration or load.
I had a spare hp pump so I threw that in and it ran the same as with the other pump. I guess I could through a new FPR at it but I'm guessing it won't change anything.
Primed psi is 34ish
Idle psi is 34ish
With Engine off it holds at 40 psi for awhile.
Not a stock tank but an older 22 gal (thanks for chimng in Kirk)
Anything else guys can think of?
Thanks.
Sat May 29, 2021 5:12 pm
I replaced the FPR with a a new one and it didn't change anything. I'll post up on CB.com and get a few more opinions. Feel free to chime in if you have any thoughts.
Thanks guys!
Thu Jun 03, 2021 9:42 pm
Perplexing
Thu Jun 03, 2021 9:52 pm
did you check your timing?
Fri Jun 04, 2021 8:04 am
I'm just stabbing at this, but could it be a dirty mass air sensor or bad TPS?
Fri Jun 04, 2021 8:06 am
I don't remember, is this mustang or explorer EFI? If it's explorer you can't change the timing.
Sat Jun 05, 2021 12:37 am
Sat Jun 05, 2021 7:55 am
Sat Jun 05, 2021 3:16 pm
Sat Jun 05, 2021 4:11 pm
It "was" a mustang efi but we swapped it over to the explorer harness and coil pack a few years ago.
Oh, I changed my air filter and cleaned the MAF a couple months ago
As for the TPS---if it were faulty, would it sputter if I rev -ed it in park/neutral. Only asking because when I rev it in neutral it sounds / responds great.
Sun Jun 06, 2021 10:46 am
Well the good thing about the explorer EFI is you can hookup a good scanner and look at all of the sensors while they are working. You can also see if it has any codes stored. I might know a guy with a scanner.
Sun Jun 06, 2021 11:08 am
Is it close to " Larry the Cable Guy"?
I videoed the FP gauge driving around the hood: idles at 36 psi and during acceleration it'd go up to 40-41 psi. I figured the FPR knows what its doing but could there be too much gas and bogging the engine down?
Sun Jun 06, 2021 12:03 pm
Sun Jun 06, 2021 2:03 pm
Mon Jun 07, 2021 4:05 pm
Post Re: EFI vapor lock....SOLVED!!!!
Nice! Now can we move onto other things? icon biggin
Mon Jun 07, 2021 4:41 pm
32,938,132 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
