www.ColoradoClassicBroncos.com - View topic - Dakota Digital VHX with EFI VSS
It is currently Fri Nov 22, 2024 1:35 am
Reply to topic  [ 5 posts ]
Post Dakota Digital VHX with EFI VSS
I am in the process of installing a Dakota Digital VHX dash gauge and all I have left is to install the vehicle speed sensor. Wondering if anyone has experience installing the gauge with a Ford Explorer EFI application? How can I get the DD VSS to work with the EFI VSS and clear the parts of the t-case that are in the way?
Wed Aug 04, 2021 7:48 am
Post Re: Dakota Digital VHX with EFI VSS
You will need to remove the original VSS and just not use it.
Wed Aug 04, 2021 9:28 am
Yup. my EFI works great w/o VSS input.
72 Bronco Sport, 5.8 EFI, NV3550
Sat Aug 07, 2021 9:28 pm
VSS seems to be a need on some. I had issues with mine dying when I idled down to a stop that VSS fixed.
Sun Aug 08, 2021 10:56 am
I used the Dakota digital sitter module so I could send the correct pulse to thr ECM and the appropriate (different) signal to the DD cruise Control module.
25th yr of ownership of my '76; ~3.5 yr frame-off restomod completed (100; 90+% by me) in '07 included '96 5.0 Explorer mated to NV4500, Terra Low D20, 4.88s F&R (ARBs) secured with Cage long arms and Deaver Leafs (5.5") topped with a Crab-style cage tied 6-points to the hot-dipped frame which rolls on 35" BFG KM2s on eagle alloys (flat back-as all trim) protected by sweet protofab plates F&R. it's never done. Just finished a delayed ( 3 yr) Explorer OBD-II upgrade, moved here. Now, needing to update emissions...seeking advice on that.
Mon Aug 30, 2021 10:48 pm
32,937,293 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
