www.ColoradoClassicBroncos.com - View topic - TFB SITREP
It is currently Tue Dec 03, 2024 11:01 am
Reply to topic  [ 215 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
 TFB SITREP
Post Re: TFB SITREP
Fri Oct 22, 2021 6:31 am
Post TFB SITREP
I wanted to add a little information about some recent trouble shooting. A few months back Willem started experiencing an infrequent miss at highway speeds, it would happen about once per trip. Fast forward to these last few weeks and swapping in a rebuilt transmission and the miss was so frequent the Bronco wasn’t drivable on the highway. With Garry’s (EFI Guy) help we started trouble shooting the systems on the Bronco to narrow down the problem.
Motor - verified compression was good on all cylinders.
Fuel system - verified fuel pressure was good at all engine loads and vehicle speeds.
Ignition system - found 2 spark plugs that didn’t look quite like the others and replaced the wires, also found one coil was acting up and replaced it as well.
EFI Sensors - confirmed MAF, cam position sensor and crank position sensor were good.
After all this was corrected or confirmed the miss still existed, from many test drives I noticed it was happening at a fairly narrow road speed of 64-72 mph, the engine RPM didn’t seem to matter. So on a test drive I pulled over and unplugged the speed sensor, we use the pass through version that sits between the speedo cable and the transfer case, and BINGO the miss stopped.
After consultation from EFI Guy we starting verifying grounds in the EFI harness and noticed the harness only had 2 grounds, not 3 and my ohms were high on the ground pins. I added a ground at the speed sensor and replaced the sensor.
I’m happy to report the miss seems to be gone, I’ll drive it a bit more at speed to confirm, but wanted to let you all know the outcome and thank Garry for his guidance.
Fri Nov 11, 2022 10:45 am
Post Re: TFB SITREP
Oh man-- glad you found it. I feel like when it comes to electrical, I just start seeing numbers floating around like in The Hangover.
Fri Nov 11, 2022 11:07 am
Post Re: TFB SITREP
Wow, what a way to track it down! Glad you got it fixed! Any idea if it was the ground or a bad sensor?
Fri Nov 11, 2022 11:11 am
Post Re: TFB SITREP
Fri Nov 11, 2022 12:29 pm
33,206,163 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
