www.ColoradoClassicBroncos.com - View topic - Misc parts wanted list
It is currently Thu Nov 21, 2024 7:28 am
Reply to topic  [ 10 posts ]
Post Misc parts wanted list
I am building a 1966 beater into a trail rig. I'm looking for these parts- they don't need to be perfect, some dents or rust is probably okay.
Upper coil spring retainer clips
Lower coil spring cups
Leaf spring shackles
Lower center firewall sheet metal (angles between vertical firewall and top of transmission tunnel)
1966-67 doors and/or door parts
1966-68 grille (small turn signals), headlight buckets, trim rings, etc
Tailgate latch handle assy
License plate bracket assy
1966 steering column dash surround (metal and the rubber part)
1966 ashtray
Steering column support bracket that attaches to firewall with 3 bolts and the column clamps to it
Perhaps someone has these takeoffs in a junk pile and will unload them cheap or free? Just need to make a rolling chassis until I get "real" axles
- Dana 30 hubs, spindles, drums, axle shafts, drive flanges or lockout hubs
- Ford 9" 28 spline standard axles (preferably with big bearing retainers)
Call or text at 303-578-8432
Gary
Tue May 31, 2022 2:45 pm
Post Re: Misc parts wanted list
I probably have the 9” axles, and possibly some other small parts, I’ll look in storage.
Tue May 31, 2022 5:34 pm
I have some lower spring cups.
Tue May 31, 2022 10:44 pm
I've got a few axles. Not sure about the retainer size. They're rusty, but you can have them.
Wed Jun 01, 2022 7:34 pm
I probably have these. I can check in my parts pile.
Wed Jun 01, 2022 8:54 pm
Profile WWW
Thanks to everyone- I believe I have PM replied.
I could also use a set of 4 steel wheels with tires that hold air. Don't need to be OEM Ford, but more narrow/stockish width (5-6") and smaller tire size (<31 x 9" or so).
Gary
1966 Bronco. 351W with Explorer fuel injection, Cage 3.5" lift w/long arms, 2" body lift, NV4500, 4.56 ARB front D44/Detroit Locker 9" rear, 35" MTRs, hydroboost brakes and 4 wheel disks.
Thu Jun 02, 2022 6:38 am
Updating the list for what I am still looking for:
1966 ashtray
Wed Feb 01, 2023 6:03 pm
I have the most of the Dana 30 parts from a disk brake conversion. I don't have any 30 axles.
Thu Feb 02, 2023 5:37 am
Thu Feb 02, 2023 8:31 am
I have a license plate bracket assembly, I even know where it’s at in storage.
Thu Feb 02, 2023 6:07 pm
32,910,937 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
