www.ColoradoClassicBroncos.com - View topic - Suspension help
It is currently Sun Nov 24, 2024 4:16 pm
Reply to topic  [ 7 posts ]
 Suspension help
Post Suspension help
About to weld in adjustable Coil buckets. I think they were welded in place for full width axles, which I don't have but wondering if the leaning out will cause me any issues?
We are 11 or 12 deg off 90.Image
Sent from my SM-G973U using Tapatalk
Sat Mar 11, 2023 7:33 pm
Post Re: Suspension help
I think you'll be fine. I ran mine with stock uppers and 79 F150/Bronco axles for several years. There was much more bow than that.
My new set up will be similar with slightly wider uppers than lowers.
Sun Mar 12, 2023 12:20 am
Everyone I've spoken with agree. There won't be any noticeable difference. Just make sure my tire won't come up and contact it.
I will be cheating the spring in a little to help them be more vertical, but I am guessing I'll only gain 5 deg or so.
I failed to get a picture, but here is where the drivers side was after welding it in solid:
Both sides are now in solid and everything is painted. I've made some straps to hold the spring in place similar to OE, and once the new springs arrive, I will build some stops so the spring can't go anywhere. Then it should be mounting it all up for the final time and see if I can flex it out somehow.
I will say it was easier than I expected to get all the stock stuff off the frame. I didn't clean it all off as some of it was left to keep the thickness for strength. But in the 10hrs +/- I have into it, I figured to be about half-way to where I am. Very pleased to know that maybe 2 more hours and I'll be testing it. Perhaps minor gains, but this gives me flexibility in the future and I know I won't miss those stiff 3.5" springs!
Mon Mar 13, 2023 10:32 am
A Bronco mod that went faster than expected? I'd go buy a Powerball ticket!
What new springs did you install? Looks like my Deavers. 5.5" lift spring set at 3.5" lift gave me great additional droop.
Mon Mar 13, 2023 11:10 am
I know right? I went with Wild Horses 5.5" coils in blue. I'd love to try taller someday, but then I get into custom springs, and it's probably cheaper to do coilovers at that point.
Went for the patriotic theme. Red tailgate, white body, blue springs!
Mon Mar 13, 2023 11:13 am
I think a longer spring than 5.5" would over extend my 14" shocks.
Just curious, your first picture looks like linear rate coils. That's why I thought they were Deavers. Is that picture the new WH coils? I thought WH coils were all progressive rate.
Mon Mar 13, 2023 11:19 am
I am concerned about the shock length. These have been on the bronco since I bought it...2003-ish?? And probably due for replacement, but I may pull one off and see if it's still doing it's job and decide from there. My Y-link arms have contacted them slightly as well, but I haven't felt any adverse affects to that.
The pictures are all of the old coils. New ones to arrive today!
Mon Mar 13, 2023 11:50 am
33,006,460 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
