www.ColoradoClassicBroncos.com - View topic - Hi-Lift or Bottle Jack or Both?
It is currently Sun Nov 24, 2024 8:13 pm
Reply to topic  [ 9 posts ]
Post Hi-Lift or Bottle Jack or Both?
I'm looking to equip my Bronco with a good jack. I'd like something small like an extended bottle jack but I know that most of these won't have the height to get the Bronco high enough to change a tire. Does anyone have any recommendations? I'd like a Hi-Lift but don't want to get one until I have a good bumper that carries both the spare tire and the jack.
Thanks.
Sun Mar 27, 2011 6:29 am
Post Re: Hi-Lift or Bottle Jack or Both?
Yep, that's what I was expecting. Guess that new bumper will come sooner than later:)
Sun Mar 27, 2011 6:35 am
But a hi-lift is dangerous. They are called widow makers for a reason. They are great but you just have to be careful. I have a hi-lift and also carry the normal floor jack. Gonna get a nice bottle jack to carry so I can leave the floor jack at home. When I ripped the sidewall open on spring creek I had to use a combo of all 3 the get it in the air and change it. It all depends on your level of wheelin on what to carry. Pick up a decent bottle jack and a hi-lift and call it good.
Sun Mar 27, 2011 7:35 am
Another good thing for jacking on the trail is a strap from axle to frame so you dont have to jack it up as far. I cant get a tire off the ground with a 4 foot hi-lift without the strap with a 5.5 WH lift.
Sun Mar 27, 2011 7:46 am
Images: 13
im with Z my friend with a samurai and i go he bring the arb exhaust jack and it great, it fills voids helps n creek beds
TRAVIS HOYLE
Sun Mar 27, 2011 9:35 am
Profile YIM WWW
Zillacon are you offering to buy us all an ARB jack foshizzle .
Sun Mar 27, 2011 8:41 pm
I was planning on a Hi-Lift for around $80.00 for the all cast version. I havent heard about the ARB Exhaust jacks. How much are the ARB's?
Mon Mar 28, 2011 9:52 am
I bought a cheap scissor jack to keep in the Bronco along with a bottle hydraulic. I tend to use the scissor more often than the hydraulic because it's lighter and has a much much greater range of lift than the hydraulic. That tiny little nub on the end of the hydraulic doesn't give me much comfort with the bronco high in the air.
I've seen scissors used for allot of strange things over the years because it can be collapsed so flat and inserted in between things like tires and crushed fenders.
I'm going to get a high lift for the trail, but I dont like using them much for actual flat tire changing.
Mon Mar 28, 2011 10:28 am
Hi-lift and stock EB jack for me.
Mon Mar 28, 2011 10:38 am
Users browsing this forum: No registered users and 61 guests
33,013,910 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
