www.ColoradoClassicBroncos.com - View topic - Batteries, what do you use?
It is currently Mon Nov 25, 2024 12:57 am
Reply to topic  [ 26 posts ]
Post Batteries, what do you use?
I have run an optima red top battery for the past 12 years now and it has never let me down, even after the bronco sat for a year non started. Two weeks ago I got the bronco out of the garage for the summer and was getting it ready for the monthly breakfast and the battery would not hold a charge. I jumped it and let the truck run for half hour then drove it and about 45 minutes later I turned it off and it didn't even have enough power to do more than a small growl barely turning the starter. I have the battery on a trickle charger now but I still think its a lost cause. So now I'm in the market for a new battery. I have heard some mixed reviews on the optima batteries now that they are made in mexico, So tell me what battery you like and what your experiences are with it. I want a good brand that holds up to the abuse of offroad driving. Help me make a good purchase! Thanks.
Mon May 30, 2011 8:33 am
Post Re: Batteries, what do you use?
In my dads we have dual duralast golds. They have been in since 99 and still hold a charge. Now I wouldn't trust the load of the winch on them but they still start everytime. I runa duralast commercial in my 79. I left my "kill switch" on in my bronco a few months ago and killed the battery. When I pulled it out it had 5 volts in it. Slapped it on the charger for a nice slow charge and it came back to life. And it's 5 years old.
Mon May 30, 2011 8:43 am
I'm not sure what to think. I ran a red top, for 10+ years and it was great. But Optima changed hands, Johnson Controls bought them, and I've heard mixed results. The Deca dual purpose battery gets rave reviews. Carquest sells them private labeled as the "Extreme" or something. They are grey bodied w/yellow top I think, I'll go look & make sure. Rrrrraaaaaaayyyyyyy2 over at CB.com, is an alternator guru. I was having trouble installing his alternator, and he said that it was a "great battery". It isn't cheap, I paid $160 or something, wholesale. It'll run a winch no problem, a red top Optima is not for a winch, you should be using a yellow top Optima for a winch & start battery.
Chad
Mon May 30, 2011 8:45 am
Images: 13
i got a yellow to run just winch, and red for starting and acc. i havnt had much problems ive owned them for 3 yrs so maybe i got lasty batch of them before mexico
TRAVIS HOYLE
Mon May 30, 2011 10:28 am
Profile YIM WWW
I killed my red top a few times and it finally died recently. I went back to Advance because the battery was still under a pro-rated warranty. Anyway, I ended up with another Red Top because the manager told me the QC issues have been resolved. He said that middle of last year Optima reps came to the store and showed them the issues and how they were fixed.
But I also bought a Battery Tender to keep it in tip top shape.
These gel batteries can't be charged by any old charger. You need to make sure it's gel compatible.
Tue May 31, 2011 7:49 am
I've had a Yellow top in my 4Runner as a 2nd battery and a Red top in my Bronco as the main. The Yellow top died after about 3 years and I wasn't able to revive it even using a desulfator on it (I replaced it with a Red top). I've only had the Red top in the Bronco for about 8 months but it seems to be working fine.
Tue May 31, 2011 8:20 am
I run dual red tops in my bronco, a yellow top in my truck, a red top in my wifes car and a red top in my car. Never had a problem with any of them. They are all of varying ages and build dates. When one dies I will replace it with another optima!
Tue May 31, 2011 9:02 am
Had a yellow top for a few years. Hated it. Dropped a Duralast in the Bronco and haven't had a problem with it since.
Tue May 31, 2011 2:08 pm
I do run a winch, electric fuel pump, electric fan on radiator, pro comp lights, radio, and gonna put a trans cooler with fan. I don't run them all at once but it does sound like if I go Optima again I will get the yellow top. Sounds like there is a few guys on here who are having decent luck with the new optima's. I will look into the other two battery types mentioned. Keep the responses coming and other batteries you have used with good results. Thanks
Akafrankcastle why did you hate the Optima?
Tue May 31, 2011 2:17 pm
If I were you, I'd think about going with a 3G alternator with that much extra electrical attached.
Tue May 31, 2011 2:19 pm
Sbolt19 what's the difference in the Alternator? A 3G? Im not very good at the electrical stuff, I leave that up to my dad. We did a test on the Alternator and he said it was charging very well. I forgot I'm also looking into a CB radio to put in the truck.
Tue May 31, 2011 2:26 pm
Tue May 31, 2011 2:28 pm
Tue May 31, 2011 2:42 pm
Images: 13
i love my 3g. it 130 amp i got mine at junk yard for 20 bucks and took me 9 min to take it out
TRAVIS HOYLE
Wed Jun 01, 2011 8:43 am
Profile YIM WWW
I have a Car Quest Battery. I kept it on a trickle charger on my workbench since last year when I tore my truck apart. Seems to be working well now that it is finally installed. I will definitely get an Optima when I need to replace it. Costco sells Optima.
Wed Jun 01, 2011 8:49 am
I will look into a 3G alternator. How many guys are using duel Batteries. I know there is a couple guys on here. How has it worked for you? Is it something I should be looking into or would it be over kill for me? What is involved with running two batteries and how did you loop yours together? Would a standard battery work for starts and then use a yellow top for running all the accessories. As I said before I'm not an electrician. lol
Wed Jun 01, 2011 12:56 pm
Don't buy into those dual battery isolaters. Just buy 2 new ones and wire them positive to positive and negative to negative.
Wed Jun 01, 2011 1:12 pm
Also never mix sizes or brands. Do both the same.
Wed Jun 01, 2011 1:16 pm
Wed Jun 08, 2011 8:22 pm
I am going to pick up a larger alternator. Will the alternator be larger than the ford one in there? I have my on board air mounted above the alternator running off the alternator pulley. Do the newer alternators have a pulley with two grooves like my bronco one?
Wed Jun 08, 2011 8:40 pm
Thu Jun 09, 2011 4:00 am
The 3G alternator should fit. There are small bodied 3G alts & large bodied 3G alts. Small bodied alts are about the same size as your stock alt. I bought a large bodied one through Raaaaaaayyyy2 on CB.com. He made me a deal on one he had from a show. Even the large bodied one fit fine, & I've got a York pump mounted directly above my alternator. You can see the top of the alt under the pump in this pic. its blue.
Thu Jun 09, 2011 7:28 am
Images: 13
i will be running duals, i am useing a dual guage to see life of battery ( got off cabelas site, and i got a dual battary selector, you can go to off for storing, one, two, or both, so i got yellow one side and a red optima and when i use winch i use switch to my yellow, and when i running a ton of things i use both
TRAVIS HOYLE
Thu Jun 09, 2011 4:42 pm
Profile YIM WWW
Thu Jun 09, 2011 6:04 pm
Images: 13
ive been running my red top n yellow top conv, for yr, not much issuse if u find problem let me know
TRAVIS HOYLE
Thu Jun 09, 2011 6:55 pm
Profile YIM WWW
goldenboy_cp - you should run both of the same type,age and size but if you just winch with one and normally run with the other then that's alright. It's not like anybody is gonna take away your birthday because you did it different. I just believe that using 2 good batteries for winching (or any other high load application) is better than one (more current available).
Fri Jun 10, 2011 9:39 am
Users browsing this forum: No registered users and 45 guests
33,020,609 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
