www.ColoradoClassicBroncos.com - View topic - standard brake booster or Hydroboost?
It is currently Sun Nov 24, 2024 11:21 am
Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Post Re: standard brake booster or Hydroboost?
I've heard it's easy to tell when a Bronco owner has just completed a hydroboost install. He's the guy who shows up to a trail ride with a broken nose and a split lip after underestimating the stopping power.
Fri Nov 12, 2010 1:09 am
Sounds great
Fri Nov 12, 2010 7:30 am
Fri Nov 12, 2010 8:04 am
Bleeding the power steering is a hot topic on ClassicBroncos.com right now. Lift the front and turn the steering wheel stop to stop about 50 times, holding it at the stops for a second each time and changing the throttle as you do it. Push the brakes occasionally as well. Then put the front back down and do another 20.
At least that's what all the posts say.
Also, don't let it run low or it will foam which requires a full 24 hours to subside.
Fri Nov 12, 2010 8:10 am
Guess this means you'll be coming by to pick up the hubs then?
Fri Nov 12, 2010 8:41 am
planning on it. when will you be around between say this afternoon and Sunday evening?
Gonna convince my missus that I NEED to drive it around.
Fri Nov 12, 2010 10:12 am
Fri Nov 12, 2010 10:57 am
Brian, I'm out wheeling then partying Sat, but home all day Sunday working on the house and doing a little welding on Billie's front bumper. You can get my ph # and addy in the member section. Give me a ring or text and come on by.
Fri Nov 12, 2010 7:28 pm
maybe tomorrow.
got home from work last night and it seems the front edge of my PS pump is leaking pretty good.
gonna pull it and see if it can be repaired.
or needs to be replaced
Sat Nov 13, 2010 12:36 pm
32,999,046 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
