www.ColoradoClassicBroncos.com - View topic - Bouncing Tach
It is currently Sun Nov 24, 2024 5:04 pm
Reply to topic  [ 68 posts ]  Go to page 1, 2, 3  Next
 Bouncing Tach
Post Bouncing Tach
My tach has been working fine for the last month or so but now it bounces all over the place. I thought this might be a bad ground but it seems to be fine. I attached it directly to the neg battery terminal and it's doing the same thing. Any ideas?
Thanks.
Sun Jun 19, 2011 7:00 pm
Post Re: Bouncing Tach
Could be a sign of a problem in the distributor. What type of ignition do you have?
Sun Jun 19, 2011 7:47 pm
It's whatever was OEM on the 1970 year. The dizzy is a new Mallory model....
http://www.amazon.com/gp/product/B000FVZHTS
In the last year I've installed:
New battery
New Flamethrower coil
New plugs/wires
New solenoid
Has the original voltage regulator and alternator.
This just started happening about a week ago.
Sun Jun 19, 2011 8:03 pm
Try adjusting the points.
http://prestoliteperformance.com/Portal ... _25_27.pdf
Mon Jun 20, 2011 12:06 am
So from those procedures, the point gap for a 27 series should be .022 for the dual-point? I'm not sure how to adjust this but I'll do some research. Thanks.
This seems to be a pretty good writeup.... http://thecareandfeedingofponies.blogsp ... butor.html
Mon Jun 20, 2011 8:40 am
Yep. You need to get one rubbing block on the peak of the cam then adjust that one only. Then turn the motor slightly to get the other rubbing block on the peak and adjust that one. It's twice as complicated with dual points.
Mon Jun 20, 2011 1:24 pm
So to be clear, I use the feeler gauge between the felt pad and the cam lobe? That's what should be .022? Thanks.
Thu Jun 23, 2011 9:45 am
No. the feeler gauge goes between the point contacts when they are all the way open.
Thu Jun 23, 2011 3:08 pm
Ok, so I checked the points, they were right on at .022. Then I checked the timing, it was off so set it back to 11. Then I changed the ground on the tach and also replaced the coil to dizzy wire. The tachometer still bounces.
One more thing now, it's running really rough, stalling and almost impossible to start without flooring the throttle after waiting 10 minutes. I'm going to change the fuel filter again but I'm now thinking it may have something to do with the mixture screws on the carb? It smells of gas horribly but there are no leaks.
Thanks.
Fri Jun 24, 2011 7:39 pm
Fri Jun 24, 2011 8:05 pm
I checked the plugs and they looked ok. They are pretty new.
Fri Jun 24, 2011 8:21 pm
I would say the coil could be going bad. Its nice to have a known good working coil to swap out and verify. Do you have an ignition ballast on the coil circuit or the resister wire? Check all of your wiring connections and verify they are making good connections.
Fri Jun 24, 2011 8:26 pm
Well, the coil is 6 months new also...but I guess it could be bad. No ignition ballast that I know of. What would that look like?
Fri Jun 24, 2011 8:28 pm
The hard starting after shutdown is most likely fuel boiling in the carb. Might need a little tweeking on the mixture screws too with this warm weather. Neither of those will affect the tach though.
Fri Jun 24, 2011 10:51 pm
Sat Jun 25, 2011 10:20 am
Thanks guys. I'm going to replace the fuel filter again and mess with the mixture screws. Still baffled on the bouncing tach.
If the tach to coil wire is in close proximity to any other wires....battery, plugs, alt. etc. could this cause issue?
Thanks
Sat Jun 25, 2011 10:38 am
you could be getting a cross signal if there is enough amps going through the other wires. Or if there is a fray in one of the wires.
Sat Jun 25, 2011 11:31 am
Or if it was running parallel to a plug wire.
Sat Jun 25, 2011 10:44 pm
What about a condenser problem?
Sat Jul 02, 2011 7:45 pm
The condenser I'd that cylinder on the outside of the dizzy right? It's new.....but it could be bad I imagine.
Sat Jul 02, 2011 9:48 pm
Sun Jul 03, 2011 8:49 am
How else would a bad condenser show itself?
Sun Jul 03, 2011 8:54 am
Sun Jul 03, 2011 11:21 am
Sounds good....will pick one up at Advance soon. Thanks guys.
Sun Jul 03, 2011 12:48 pm
New coil fixed both the bouncing tach and the stalling/stumbling problems! My old coil was only 1 year old.
Fri Jul 15, 2011 8:45 pm
Images: 1
You never know what's going to happen with aftermarket junk!
Fri Jul 15, 2011 10:35 pm
Well, the bouncing tach is back again. I can't figure it out. It was fine for about 3 days after I put the new coil in, then all of a sudden it starts bouncing again and the bad performance is back. The new condenser should be here today so I'll try that. It's getting annoying.
Tue Jul 19, 2011 11:52 am
Tue Jul 19, 2011 12:16 pm
Ditch the points and go with a oem electronic ignition.
Tue Jul 19, 2011 12:20 pm
Tue Jul 19, 2011 12:35 pm
Users browsing this forum: No registered users and 21 guests
33,007,920 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
