www.ColoradoClassicBroncos.com - View topic - Bad u-joint?
It is currently Mon Nov 25, 2024 1:57 am
Reply to topic  [ 10 posts ]
 Bad u-joint?
Post Bad u-joint?
So I had a little driveline vibration on the Super Duty when I was driving it home from Denver. Haven't had much chance to look at it and the truck has been parked. Decided to pull the driveshaft after a quick inspection. I'm thinking this u-joint might have been bad.
Tue Jun 28, 2011 11:29 am
Post Re: Bad u-joint?
Bad for you, good for scrap!
I should probably go grease mine!
Tue Jun 28, 2011 11:33 am
Yeah. After pull the driveshaft, I'm gonna probably replace all the u-joints. Good prevention. Plus both caps on the next joint just fell off with no effort. Don't think I saw any grease in them.
Tue Jun 28, 2011 11:35 am
You're nuts. That has another 50k in it, easy.
Tue Jun 28, 2011 12:09 pm
That'll buff out.
Tue Jun 28, 2011 1:12 pm
laughing2 eh, 25k at best. Have to save the rest for the Bronco.
Big thing that gave it away...the half a post seen the the bottom was not only not seated in the bearing cap, it was kicked over almost a full inch. Some heavy throttle and I'd probably have sheared it right off.
Tue Jun 28, 2011 1:14 pm
id go with u joints that are non grease-able they're much stronger on a diesel they have alot of torque . i have been through a couple and they seem to last longer and i have mine chipped so i like to mash the pedal and watch the smoke.
Tue Jun 28, 2011 6:24 pm
Tue Jun 28, 2011 9:34 pm
Images: 1
Weld up some nuts to the old ones and just die grind round vwala, reconditioned u joints
Tue Jun 28, 2011 10:38 pm
Hell, I bet you could just use a helicoil to stick all the parts together.
Tue Jun 28, 2011 10:57 pm
Users browsing this forum: No registered users and 70 guests
33,022,641 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
