It is currently Mon Nov 25, 2024 1:33 am
[ 10 posts ] |
Bad u-joint?
So I had a little driveline vibration on the Super Duty when I was driving it home from Denver. Haven't had much chance to look at it and the truck has been parked. Decided to pull the driveshaft after a quick inspection. I'm thinking this u-joint might have been bad.
Tue Jun 28, 2011 11:29 am |
Re: Bad u-joint?
Bad for you, good for scrap!
I should probably go grease mine!
Tue Jun 28, 2011 11:33 am |
Re: Bad u-joint?
Yeah. After pull the driveshaft, I'm gonna probably replace all the u-joints. Good prevention. Plus both caps on the next joint just fell off with no effort. Don't think I saw any grease in them.
Tue Jun 28, 2011 11:35 am |
Re: Bad u-joint?
You're nuts. That has another 50k in it, easy.
Tue Jun 28, 2011 12:09 pm |
Re: Bad u-joint?
That'll buff out.
Tue Jun 28, 2011 1:12 pm |
Re: Bad u-joint?
eh, 25k at best. Have to save the rest for the Bronco. Big thing that gave it away...the half a post seen the the bottom was not only not seated in the bearing cap, it was kicked over almost a full inch. Some heavy throttle and I'd probably have sheared it right off.
Tue Jun 28, 2011 1:14 pm |
777mechanic
Re: Bad u-joint?
id go with u joints that are non grease-able they're much stronger on a diesel they have alot of torque . i have been through a couple and they seem to last longer and i have mine chipped so i like to mash the pedal and watch the smoke.
Tue Jun 28, 2011 6:24 pm |
Re: Bad u-joint?
Tue Jun 28, 2011 9:34 pm |
cobshane
Re: Bad u-joint?
Weld up some nuts to the old ones and just die grind round vwala, reconditioned u joints
Tue Jun 28, 2011 10:38 pm |
Re: Bad u-joint?
Hell, I bet you could just use a helicoil to stick all the parts together.
Tue Jun 28, 2011 10:57 pm |
[ 10 posts ] |
Users browsing this forum: No registered users and 75 guests |
