www.ColoradoClassicBroncos.com - View topic - O2 Bungs or Tap
It is currently Sun Nov 24, 2024 4:55 pm
Reply to topic  [ 4 posts ]
 O2 Bungs or Tap
Post Re: O2 Bungs or Tap
Aaa metric. I think they are 18x2.5mm or something like that. Or exhaust pros. I've got some there too.
Tue Jun 14, 2011 4:47 pm
You can also cut down a set of 18mm spark plug extenders. You can usually find them in the HELP! section of the local auto parts store. Works like a charm and usually less $$. If you have the time to wait, Summit sells them for $5 or so and I usually have some on the shelf.
Joe
Tue Jun 14, 2011 6:23 pm
Yep. Same thread as the big spark plugs. I think I have some spark plug taps.
Tue Jun 14, 2011 9:46 pm
I was able to find the bungs at NAPA for about three dollars
Sat Jul 30, 2011 10:19 pm
Users browsing this forum: No registered users and 19 guests
33,007,612 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
