www.ColoradoClassicBroncos.com - View topic - Bouncing Tach
It is currently Sun Nov 24, 2024 4:27 pm
Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3
 Bouncing Tach
Post Re: Bouncing Tach
Damn comedians slap
Tue Aug 02, 2011 3:48 pm
Is the only common part left the dual point distributor?
Tue Aug 02, 2011 4:39 pm
Tue Aug 02, 2011 4:42 pm
I know Viperwolf would solve it if he was able to get near it, but since so much has changed in such a sort time I see where he is going, looking for what hasn't be swapped out via trouble shooting. Do you have the original dizzy still? I know it isn't ideal but you could swap it out (30 min job) and see what happens. In addition you could try to rule out other contributing systems like fuel & air, I think you already swapped the fuel filter right? Recent carb or other fuel system changes?
Tue Aug 02, 2011 5:02 pm
wondering if the points are both correct as is set correctly , if one isn't set this could be part of the ruff running and bouncing tach .
Tue Aug 02, 2011 8:10 pm
Images: 1
Dual points are a good upgrade but are super pain in the ass to set perfect. Looks like you just need to dump it. Kiddin, you just need to get that thing to a tech class.
Or else your just gonna be dumping money in to unnessary parts
Tue Aug 02, 2011 8:54 pm
Yep, I'm going to leave it alone for a while. I think I do still have the old dizzy and might try that. Thanks.
Wed Aug 03, 2011 12:26 pm
before changing dizzy try opening one set of points until they don't touch cam and see if the problem is still there , just one more thing elimanated
Thu Aug 04, 2011 8:30 am
33,006,622 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
