www.ColoradoClassicBroncos.com - View topic - Tip to Tail Transmission setup
It is currently Sun Nov 24, 2024 12:58 am
Reply to topic  [ 7 posts ]
Post Tip to Tail Transmission setup
Looking for a complete auto or standard setup, auto would be a C4/adapter/D20 transfer case set including the flywheel/torque converter/shift/kick down linkage. For a standard set up I'm looking for a 4 speed/adapter/D20 transfer case set including the bell housing/pressure plate/clutch/shifter/clutch linkage. This would be for the project Bronco that I'll be building with my older son next summer. I'm open to alternative combos, but I'm trying to keep the cost down since this is his truck, he is 14 now and the goal is to have it complete by the time he turns 16.
Tue Aug 02, 2011 7:28 pm
Post Re: Tip to Tail Transmission setup
I can get you a rebuilt C4 from flexplate to D20 adapter.
Thu Aug 04, 2011 12:12 pm
Phil, that would work great, I have an unkown condition T-shift D20 that I could bolt it to. What are you looking to get out of it? I could easily send you the funds, do you need it out of your way or could you hold onto it for a couple of months until I get home on R&R?
Thu Aug 04, 2011 12:18 pm
Including complete rebuild with all new seals, rear servo, shift kit, new bands, new clutches, cooling mods, rebuilt converter, new flexplate (need to know balance), blockplate, vac line, kickdown rod, NSS, new adapter seal, spud, adapter and bearing retainer it would be approximately $950. Basically everything except a shifter. It would work fine with the T shift D20 and require no driveshaft or crossmember mods to bolt in.
Thu Aug 04, 2011 12:58 pm
Is this something you want gone soon or are you going to build it? I'll need to save up a few more dollars to afford it and wouldn't be able to put it to use until spring.
Thu Aug 04, 2011 2:39 pm
I have it all disassembled and cleaned up now. I can hang on to it and put it together when you're ready for it. I don't mind storing it.
Thu Aug 04, 2011 3:56 pm
Thanks Phil, let me know the progress and we can work out the payment, no rush on my end.
Thu Aug 04, 2011 7:42 pm
32,987,327 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
