[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - Need rear drive shaft or CV-Joint parts ASAP
Jonah had his front ujoint go bad on his rear driveshaft. It also damaged both pieces that hold the U-joint (part on the rear ouput from the t-case and front part on the CV) If anyone has anything let us know. Would like to pick up ASAP.
Thanks Scott
303-489-1209
Fri Aug 05, 2011 3:40 pm
Re: Need rear drive shaft or CV-Joint parts ASAP
Can't help with parts, but if you wind up buying new, check with a local driveline shop. Having mine done cost about $10 with better parts than it would have cost me to get the parts and do it myself.
