www.ColoradoClassicBroncos.com - View topic - 66 Bronco Project
It is currently Thu Nov 21, 2024 1:18 pm
Reply to topic  [ 206 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 66 Bronco Project
Post Re: 66 Bronco Project
Yes, pull the 3rd member out of the donor and swap it into your current rig. You'll be better off in the long run that way. You can add a locker later.
Wed Aug 17, 2011 7:49 am
Ok I pulled both axle shafts and both gears out of each Bronco and I'm looking at both the gear sets right now and it looks like the gear set I pulled from the Bronco I'm building that has a set of 3.54 gears has an actual locker in it and the one I pulled from locker doner doesn't..looks like its limited slip..guess what I'm wondering now is if I can pull the gears off the one with the locker and put the 4.10 gears on that locker? Ill take it to a shop to have it done of course but does anyone know if that's possible or will I have to order a locker?
Im your huckleberry
Wed Aug 17, 2011 1:05 pm
Check your splines. Should be 28 (if stock). If the locker and your axles have the same, then yes.
I'm not familiar with Limited slips, but are they the carrier or are they lunchbox lockers inside the carrier?
Wed Aug 17, 2011 1:41 pm
Ok just dropped the guts to the two off at my mechanic he's gonna swap them out for me should have them back tomorrow and put back together..installed everything else except the body lift I loosened 2 bolts and the second snapped so I got freaked out and put it back together I think ill save that one till after summer don't want a body lift ruining my chance for wheeling..tomorrow ill install my door inserts..rear seat belt, and finish the axle just leaves me with power steering pulley and order a front detroit..winch will be in tomorrow too..I estimate mid next week she will be on the road
Im your huckleberry
Wed Aug 17, 2011 3:26 pm
You can expect some body bolts to snap if your body hasn't been removed in a while. Pretty common. Did your new kit come with new bolts? You might think about trying to treat those with something that will resist rust. Maybe paint them or something?? Got to be some better ideas because I doubt paint sticks to bolts too well. Maybe mcmaster.com has some corrosion resistant bolts??
As a matter of fact: http://www.mcmaster.com/#standard-cap-screws/=dnvmf5 (second option down on the right). May cost you up front, but hopefully you would avoid breaking bolts in the future. And I can see more mods in your future when you get out there and wheel this beast.
Did you replace that broken bolt? You probably should.
Wed Aug 17, 2011 3:34 pm
Well I might attempt to drill through the bolt to replace it gonna be a pain in the butt I'm sure ill be snapping a lot more they've been in there for quite some time so I'm sure they are rusted out..oh well ill deal with it later and yes there's definetly gonna be a new suspension kit being installed in the near future gotta have that awesome flex..cant wait to get it moved out of the garage to snap some pics of it so u guys can check out the new interior and all the other mods I made looks totally different from the last pics I posted..
Im your huckleberry
Wed Aug 17, 2011 5:08 pm
we're waiting... drool
Wed Aug 17, 2011 5:11 pm
Images: 1
Thu Aug 18, 2011 11:29 pm
Fri Aug 19, 2011 7:21 am
Well crap just got a call from the mechanic working on my rear gears and he said he put the 4.10 on the locker and went to install it again and it wont fit so back to the old drawing board..I guess ill just have to buy and new front and rear locker for it..think ill go detroit in the front and I guess a TRUE track in the rear..what a bummer..and ill get pics on here asap cant move the Bronco at the moment cuz the gears are all ripped out of it but when get that together ill get the pics
Im your huckleberry
Fri Aug 19, 2011 10:24 am
Something ain't right. If both were 9" axles, it should fit. Maybe wrong bearings??
Are you planning to drive the rig on the street much? If not, I would go detroit in rear and front. Or if you're trying to save a little money, truetrac in the front. Detroits don't have great road manners, but are tolerable. You won't feel it in the front in 2WD.
Fri Aug 19, 2011 11:17 am
Ill go with the detroit up front..its just the rear I'm worried about..I don't understand how it didn't fit but hey he's the mechanic..I think if I throw a TRU track or something in the rear that only kicks in when u punch it that would be fine don't really wanna eat up them new tires..ill just get to looking on the net I guess
Im your huckleberry
Fri Aug 19, 2011 1:29 pm
Ok fellas here it is finally got it fired up and pulled out of the garage only thing left to do on it is install rear seat belts,bleed the brakes and fab the rear bumper and gas can holder and install the winch and bumper and Im ready to wheel!!
Im your huckleberry
Tue Aug 23, 2011 7:34 pm
and more
Im your huckleberry
Tue Aug 23, 2011 7:40 pm
wow.............that is the definition of total chaos...............you have been working your tail off
glad to see your nearing completion on such a beautiful rig
Tue Aug 23, 2011 7:48 pm
Well unfortunetly there is one thing Im not happy about and thats the inserts it seems my painter didnt prime it and just shot over the white resulting in a brighter blue insert...some peoples kids! but oh well check this out
Im your huckleberry
Tue Aug 23, 2011 7:53 pm
Im your huckleberry
Tue Aug 23, 2011 7:58 pm
Amazing tranformation Chaos. I am so impressed. Color, rims, lift, etc. turned out amazing.
Tue Aug 23, 2011 8:00 pm
Im your huckleberry
Tue Aug 23, 2011 8:08 pm
Fantastic work!! Can't wait to see it in person!
Tue Aug 23, 2011 8:11 pm
It looks amazing, love the blue and the interior is nice.
Tue Aug 23, 2011 8:15 pm
Im your huckleberry
Tue Aug 23, 2011 8:19 pm
Tue Aug 23, 2011 8:42 pm
Im your huckleberry
Tue Aug 23, 2011 8:46 pm
Stunning! Bring that thing out so we can drool on it!
Tue Aug 23, 2011 9:36 pm
Im your huckleberry
Tue Aug 23, 2011 10:48 pm
yeeeeeeehaa! She looks sweet, can't wait to meet you and see her in person
Wed Aug 24, 2011 5:43 am
Lookin really amazing! Quite the transformation from the beginning. Need to update that avatar pic poke
Wed Aug 24, 2011 8:25 am
Looks awesome!! You will be ready for the independence trail system in no time!! Jk, never take your bronco in there looking like that!!
Wed Aug 24, 2011 12:59 pm
Im your huckleberry
Wed Aug 24, 2011 3:12 pm
Users browsing this forum: No registered users and 15 guests
32,919,003 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
