[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - rear drum brake/parking brake parts
I'm trying to connect the parking brake and saw I was missing some parts in the drums. If you've got these laying around, it could same me some $$ in buying kits. I need: 1 parking brake spacer (spreader bar and spring) 2 adjusting levers 2 cables (from adjusting levers)
Fri Nov 25, 2011 9:03 pm
Re: rear drum brake/parking brake parts
What size drums? 10" or 11".
Fri Nov 25, 2011 9:13 pm
Gregg
I'm assuming 10. The drum is stamped with "MAX-DIA-10-9"
Users browsing this forum: No registered users and 21 guests
