www.ColoradoClassicBroncos.com - View topic - ford OBD1 code reader needed
It is currently Mon Nov 25, 2024 9:16 am
Reply to topic  [ 3 posts ]
Post ford OBD1 code reader needed
Thought I would post up here on this as most of you being local makes more sense than some other boards... anyway in the past i have always read codes by counting the blinks from the CEL on my big bronco. I have been entertaining picking up a reader to just simplify trouble shooting etc but wanted to see if anyone had a Ford OBD1 reader that they would be willing to loan so I can trouble shoot a CEL that popped up after I did some work on my 94 Bronco. I know its a bit of a long shot but I would appreciate it - jut going cross eyed recounting blinks ;)
Mon Nov 28, 2011 9:23 pm
Post Re: ford OBD1 code reader needed
I think I still have one around as well.
Tue Nov 29, 2011 4:32 am
Thanks Dan for the scanner and the offer bob.
Got passing codes on everything but the key on engine on test which flashed a 311 code for the thermactor air system. This is the emissions and/or vaccum system.. I replaced my vacuum lines a coupe years ago and think i might have a leak or bad connector on the emissions stuff or the air bypass valve is toast.. either way not a big deal, truck runs great just want to get rid of the CEL that comes on after driving for a while.
I will get the scanner back to you this week!
Mon Dec 12, 2011 9:55 am
Users browsing this forum: Google [Bot] and 41 guests
33,034,677 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
