Colorado75bronc
Re: the cutting of ketchup
looks great, you def. need to build some extended arms, i used 2" od. 1/4" wall DOM and welded in a threaded insert, and used a 1" heim, probably should've used johnny joints but couldn't afford em' at the time, and im pretty happy with it, and it drives great and i gained 2 degree's of caster with 5.5" of lift
Wed Jan 04, 2012 9:30 pm |
PonyCorral
Joined: Fri Dec 17, 2010 2:42 pm Posts: 297 Images: 0 Location: Arvada
If you find some other ings and wanto to get rid of those keep me in mind!
_________________ 74 Ranger 65 Fastback
Sat Jan 07, 2012 12:48 am |
PonyCorral
Other beauty RINGS that is...
Sat Jan 07, 2012 12:49 am |
PonyCorral
Sounds Good!
Sat Jan 07, 2012 10:04 am |
May wanna look at the Stonecrusher extended arms. I contacted Stonecrusher last week and is becoming a vendor on our site very soon. We talked about combined shipping and mass buys as well http://www.stonecrushersteering.com/OTHER_PRODUCTS.html
Sat Jan 07, 2012 7:20 pm |
You have to watch those stone crusher add on's. They will bend your radius arms right where they attach. Im running the extensions but boxed in my whole radius arms with 1/4" angle iron. These things will not bend. But they weigh something like 90 lbs each. Only thing I wanna do is cut the ends off and put on a johnny joint with new frame mounts. Currently I still have stock bushing in the back. They still work great tho.
Sat Jan 07, 2012 11:47 pm |
Very happy with my arms from Clint too. I have one that squeaks bad when the exhaust heats them up, but I just need to wrap my exhaust.
Mon Jan 09, 2012 9:10 am |
I was just on Clint's (Battlement Fab) website and cannot believe all the cool Bronco stuff he builds. The extended arms look amazing: http://www.battlementfab.com/Radius-Arm-Kit_p_8.html
Mon Jan 09, 2012 10:08 am |
