www.ColoradoClassicBroncos.com - View topic - Rox Crusher's frame off refresh and 5.0 EFI swap
It is currently Mon Nov 25, 2024 1:26 am
Reply to topic  [ 283 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 10  Next
Post Re: Rox Crusher's frame off refresh and 5.0 EFI swap
Mon Jan 23, 2012 8:17 am
is this build done yet? ;)
Mon Jan 23, 2012 4:37 pm
Mon Jan 23, 2012 6:01 pm
fixed it.............it was creeping me out too
Wed Jan 25, 2012 6:39 pm
Thanks, I didn't want to have to use the forum's Ignore function.
Wed Jan 25, 2012 7:43 pm
Welcome back Rox.
Thu Jan 26, 2012 9:16 am
Purty!
Thu Jan 26, 2012 11:38 pm
Sun Jan 29, 2012 7:55 am
Keep plugging away! It is going be be sweet.
I always keep mumbling "Baby steps, baby steps" and try to do a little something when I get the chance.
(It is from "What About Bob" a Billy Murray movie)
Hope you start feeling better.
Sun Jan 29, 2012 8:19 am
I think I will make my own lines as the consensus is the pre made ones are crap.
Sun Jan 29, 2012 12:48 pm
Years ago, I bent up a set of 3/8" & 5/16" steel lines with a tubing bender & flare tool and have been happy with them. During my EFI swap, I had to do some gorilla work to make things match, so my lines aren't so pretty as they used to be. I'm sure with the drivetrain out & the body off, it would be pretty easy to get good results.
Sun Jan 29, 2012 5:40 pm
Today I decided I am going to get a ViperBuilt 4R70W to go with the 5.0.
icon biggin
Fri Feb 10, 2012 1:11 pm
So is the advantage of the 4R70W having the overdrive and better streetability? Do you need an AOD specific computer for it since it's electronically shifted? Sorry for the newb questions, still reading up on them deciding what I wanna do with mine when it comes time.
Fri Feb 10, 2012 1:52 pm
I'm not super knowledgeable, but I think you can either use an OBDII computer w/some kind of tuner, or there is a stand alone product called the Baumenator (sp?) that allows full control of the trans.
The 4R70W also has the ability to electronically lock the torque converter, some add a switch to allow manual control of the lock up. With the tuner or Baumenator, you can really tune the shift points & how the trans acts.
I wanted a 4R70W for a while, now I want a Vip4R70W. I'm waiting till I replace my D20, the 4R70W bolts directly to an Atlas.
Fri Feb 10, 2012 1:56 pm
Hmmm can you use the 4R70W with the D20 though or would you have to go to something else? I'm not looking to do a serious crawler and those Atlas's are spendy
Fri Feb 10, 2012 2:50 pm
You can use the AOD / AODE / 4R70W with the D20 but it requires an adapter kit which is roughly 500 bones.
Some guys go with Atlas transfer case which is even more expensive.
Some guys go with a 205 transfer case which is a direct bolt up but it is big and bulky and I think the gearing is less desirable.
I am planning to go with the 4R70W, adapter, D20, and Optishift controller from Baumann.
I have budgeted 1,500 for this upgrade which will really just help me with the overdrive.
C4 4R70W
1st gear 2.46:1 2.84:1
2nd gear 1.46:1 1.55:1
3rd gear 1.0:1 1.0:1
4th gear 0.70:1
Reverse 2.18:1 2.32:1
The more expensive related costs will be re-gearing the axles to get the best of both worlds.
Fri Feb 10, 2012 3:59 pm
thanks for the info, it's good to know. I'm looking to make mine DDable including some extended trips in CO and possibly UT so having the OD on the highway sounds like a better way to go over the C4 since mine needs to be replaced or rebuilt anyways. Does it matter which year/model the 4R70W comes from? I was looking over the 'Building a bullet proof 4R70W' sections at http://www.tccoa.com/articles/tranny/tr ... ndex.shtml and noticed that different makes/models had different strength/size output shafts and a couple other items seemed to vary by year. Wondering if I should be looking for like a late 90's/early 2000 explorer 5.0 and 4r70w.
Fri Feb 10, 2012 4:29 pm
The best 4R70W for us would come from 1998 - 2000 Explorer (but don't look just yet as I haven't found one for me just yet)
icon biggin
A couple minor changes in the 2001 model which was only made for half a year as they did a complete redesign for 2002.
Fri Feb 10, 2012 4:35 pm
1998 and up for the electric solenoid? No worries, I don't think I'll be seriously looking until some time in the spring when I start disassembling mine. Hopefully you'll find one by then!
Fri Feb 10, 2012 4:53 pm
You really need to regear to take advantage of the OD, if you are running 4.10's w/33" tires, you'll end up running under 1900 rpm at 65 MPH, and you will not like that. When I swapped my f/w axles, I dropped from 4.10s in my stock axles to 3.50s in my big axles, and I dropped from 2700 rpm to 2200 rpm at highway speed, and I wouldn't want to go any lower, unless you have a 351. You can turn the OD off, with the shift controller, but then you are really just running a C4 with a lower 1st gear.
I think lots of guys with 33's end up running 4.83 or 5.13 gears. It puts you back into the powerband at highway speed.
Fri Feb 10, 2012 7:35 pm
Post Rox Crusher's frame off refresh and 5.0 EFI swap
Fri Feb 10, 2012 9:08 pm
Fri Feb 10, 2012 9:34 pm
Fri Feb 10, 2012 11:47 pm
Typical, a basic EFI swap degrades to "The Decade of Progress" endless build thread & Jeff ends up with truck he doesn't want to see a gravel road, let a lone a 4x4 trail. You know you'll have to say "NO" sometime. Of course you could always go 4BT, full width D60's, 40s & boat tailing, are always an option too, oh yeah 4 links & coil overs are cool.
Jeff, it was cool meeting you and I'm glad we got to run a couple trails before you decided to do this basic refresh & EFI swap.
LOL, just kidding, I hope you can get this thing up and running before summer. Good luck, I'll be watching.
Sat Feb 11, 2012 12:30 am
Sat Feb 11, 2012 6:05 am
Sat Feb 11, 2012 6:07 am
Yea yea.....I hear ya! I also take donations.....Visa, MasterCard, and CASH:)
Sat Feb 11, 2012 7:54 am
Sat Feb 11, 2012 8:29 am
Summertime in Colorado is one hell of a motivator - top down and music up. I bet Rox, 777, Dsmith, Pony Corral, and Airbur are back on the road before summer.
Sat Feb 11, 2012 10:53 am
got my welder out and started stitching some of the inner fender seams back together
Apparently welding isn't like riding a bike, especially when the parent surface (metal?) looks like this.
Let the "booger welds" comments fly !
Sat Feb 11, 2012 6:30 pm
33,021,154 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
