It is currently Fri Nov 22, 2024 5:48 pm
[ 19 posts ] |
4 Helo 17x9 Chromed Aluminum wheels with center caps & lugs
I have a like new set of 4 Chromed Aluminum 17" x 9" wheels that were mounted once and probably have 5 miles on them. There is absolutely nothing wrong with this set they were mounted briefly however wheels turned out to be too big for what was needed. These will fit Most Ford Superduty's from 1999 to present. They are in great shape i didn't find any chips or curb rash. There might be some small scratches since they have been stored for over 3 years in a garage, but probably just need a good wipe down and they will look like new. I have a full set of center caps and a full set of lug nuts (acorn style) for all 4 wheels. These are the specs: Helo model #HE8047987206 Wheel size: 17x9 Lug Pattern: 8/170 (Should fit most Ford Superduty trucks 1999 to present) Offset: +6mm Center hole size: 5 1/4" Helo HE804 Guns. This wheel is a one-piece chromed aluminum wheel. It is direct bolt with conical seat lug holes for use with acorn style lugs. Asking $400 or any reasonable offer. If your interested give me a call or email me Chris 951 907 3894
Tue Jan 31, 2012 3:28 pm |
Re: 4 Helo 17x9 Chromed Aluminum wheels with center caps & l
FWIW '99 - current Superduty's have the same bolt pattern, but there were different factory offsets starting in '05. Might help sell them.
Wed Feb 01, 2012 8:21 am |
Thanks I will add that to the ad!
Wed Feb 01, 2012 9:22 am |
50 bucks. My final offer.
Wed Feb 01, 2012 12:27 pm |
i'll take trades... ;)
Wed Feb 01, 2012 3:31 pm |
Wed Feb 01, 2012 5:09 pm |
built 351W for the FSB ;)
Wed Feb 01, 2012 5:15 pm |
Cant help you there.
Wed Feb 01, 2012 5:17 pm |
darn...
what about plumbing, tile or carpentry? i need to redo my bathroom.. need a few things done before i gut it.. looking for someone to do tile work, build a shower tile shower and floor.. i need a sink cabinet built to fit in a small old bathroom.. i need a plumber to plumb up the steam shower and new shower outlets.. blah.. so depressing..
Wed Feb 01, 2012 5:26 pm |
I dont do any of those but we do have a plumber in the club. Plumbdoctor. One of my good buddies does tile. Not sure of his prices.
Wed Feb 01, 2012 5:31 pm |
cool might have to hit him up..
other than that i need the money to keep my build going ;)
Wed Feb 01, 2012 5:39 pm |
Dammit chris you really got me thinking about these. Let me price out some tires. Where's the clean shiney pics you said you would get?
Mon Feb 20, 2012 9:36 am |
i will bring one in thaw it out and give it a good wipe down. They aren't perfect but are pretty good honestly, I think with a slight polish they will look brand new.
I have not seen any gouges or abuse on them but i haven't been over them with a fine tooth comb.
The center caps are in good shape as well, however they do have a few pits in them since they are plastic, but since you aren't 1 foot away from them all the time you would never see the pits...
Your putting them on a truck anyway ;)
and rememeber any reasonable offer ;)
Mon Feb 20, 2012 9:53 am |
I wanna test for one to make the the offset will work. They look like they have a big backspace to them.
Mon Feb 20, 2012 9:57 am |
sure not a problem we can work something out, I can give you one or two if needed to make sure they will work.
Mon Feb 20, 2012 9:59 am |
I am sure you know, but +6mm means it's 6mm outboard of center making the inside of the wheel deeper than the outside.
From what I can find online, that matches the factory specs, but factory wheels are only 7" wide, so you'll have another inch inboard and out with these wheels. With a leveling kit and 285/75r16's I nearly rub on the rear corner of the front fender. Don't know how close to the spring I get, but it does not hit.
Mon Feb 20, 2012 10:07 am |
Jd that's what I was worried about. Im not leveled yet and wanna step up to 285's.
Mon Feb 20, 2012 10:53 am |
Mon Feb 20, 2012 12:39 pm |
Hey Chris you mind throwin one of these in at the breakfast next week? I'd like to test fit one and see how I like them.
Mon Mar 05, 2012 9:33 pm |
[ 19 posts ] |
