Register •
FAQ
• Login
It is currently Sun Nov 24, 2024 9:55 pm
[ 6 posts ] |
mwlynch3
Dumb question....
So the axle code on my '74 says A58. Anyone know what gears I might possibly have? I only found that A5's are 4.11s.
After a little research I found that it is also an HD. Is it safe to assume the HD means heavy duty? or am I way off base here?
Thanks. Mike
Sat Feb 25, 2012 9:36 pm |
Moab Mike
Re: Dumb question....
Are you certain it doesn't say A5J? A5 would indicate a 9" with 4:11 gears and LS. I'm not sure what an 8 would indicate, a J would be PS on the Dana 44.
Sat Feb 25, 2012 10:03 pm |
A5 is 4.11 limited slip in the 3300 lb axle. 8 is front limited slip without power steering.
Sun Feb 26, 2012 1:04 am |
mwlynch3
Thank you guys.... I appreciate the help.
Any one have a guess on the "HD" thing?
Mike
Sun Feb 26, 2012 9:35 am |
The 3300 lb capacity axle is heavy duty. It was required with the 4900 lb GVWR (U152) and optional with the 4500 lb GVWR (U151).
Sun Feb 26, 2012 11:47 am |
mwlynch3
Thank you Viperwolf.
Sun Feb 26, 2012 5:16 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 15 guests |
