www.ColoradoClassicBroncos.com - View topic - Brakes and lack thereof
It is currently Sun Nov 24, 2024 9:41 pm
Reply to topic  [ 6 posts ]
[quote][/quote]The brakes on Drews bronc o have been weak since we installed the new motor. I am wondering if something should be connected here? And if so what?
Sun Feb 26, 2012 2:18 pm
Post Re: Brakes and lack thereof
That is the vac port for the power brakes. Mine was plumbed to the large vac port on the front of my Edelbrock carb. Don't know if its "manifold vac" or what, but it needs hooked up to constant vac or you won't have power brakes.
Sun Feb 26, 2012 2:20 pm
There should be a hose running from the large white port on the front of the booster to a vacuum source on the intake or carb.
Sun Feb 26, 2012 2:22 pm
Post Brakes and lack thereof
My booster hose goes to a 90 degree adapter threaded straight into my intake manifold
Sun Feb 26, 2012 2:36 pm
Looks like if you pull the vac line from the carb it can be manifold vac or ported vac, you want manifold vac. Ported vac is used for dizzy advance & emissions junk, it doesn't see vac till the throttle is opened, and you want vac all the time, or you won't have power brakes unless you are on the gas (a little counter productive). I was trying to remember stuff from when I installed my carb 15 years ago.
Sun Feb 26, 2012 2:44 pm
You guys are good!
vacume hooked up and breaks are stellar! Thanks
Sun Feb 26, 2012 6:16 pm
33,015,669 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
