www.ColoradoClassicBroncos.com - View topic - EFI questions-Fuel pressure guage and regulator
It is currently Sun Nov 24, 2024 9:31 pm
Reply to topic  [ 8 posts ]
Post EFI questions-Fuel pressure guage and regulator
Does anyone have a recommendation for a fuel pressure guage and regulator?
Pictures would be helpful too.
I am using 1991 Mustang fuel rails.
Thank you,
Tod
1966 Bronco - 408 roller cam, Explorer serpentine, NV3550 5spd, hydroboost, 35s, 4.56 gears
Tue Feb 28, 2012 9:05 pm
Post Re: EFI questions-Fuel pressure guage and regulator
The stock regulator is fine unless you have a unique combination of parts that makes an adjustable one necessary.
I used AN-6 hose so adding a gauge was easy.
Wed Feb 29, 2012 12:41 am
I would like the ability to monitor and play with the pressure.
What brand are you using?
Can I adapt it to fit on the shraeder valve? I am using the stock rails and fittings.
Thank you, Tod
Wed Feb 29, 2012 4:37 am
Monitoring pressure with a gauge is good. Playing with the pressure may not be so good. Really if the EFI system is working as it should there is no reason to change the pressure.
I have seen gauges that screw to the schrader port. I picked mine up at On-Track. http://www.ontrackperformanceparts.com/
Wed Feb 29, 2012 11:05 am
I like the idea of keeping it simple too. I will just get the guage for now.
I love the look of your hoses with AN fittings. I like the idea of a more secure connection too.
I will have to learn how to build the hoses, hopefully the tools are not cost prohibitive.
Wed Feb 29, 2012 11:00 pm
I used a vice, a couple wrenches, and a sharp chisel to cut the hose.
Wed Feb 29, 2012 11:54 pm
Thu Mar 01, 2012 5:08 am
I also used the stock regulator and picked my pressure gauge up at On-Track.
'77 - efi, 302, detroit 9"rear w/4.56, D44 (locked), 35" M/TR's, Roll Cage
Thu Mar 01, 2012 12:08 pm
33,015,263 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
