www.ColoradoClassicBroncos.com - View topic - Tubing Flare Tool
It is currently Wed Nov 27, 2024 8:42 pm
Reply to topic  [ 8 posts ]
 Tubing Flare Tool
Post Tubing Flare Tool
I had to cut the rear brake diff tubing to get the stripped piece out of the old wheel cylinder. I could buy a the whole new rear tubing ( from WH ) for less than a CB.com recommended double flare tool. Does anyone have one I can borrow?
Mon Apr 09, 2012 3:37 pm
Post Re: Tubing Flare Tool
I've got one for single flare. You can also go this route:
http://www.harborfreight.com/double-tub ... 66534.html
I'd just buy the hard line kit from WH and save some hassle, esp when you figure on buying the tubing as well. If you were redoing all the brake lines, then a flaring kit is a better deal. If you do make your own, you're also welcome to borrow my brake tubing bender.
Mon Apr 09, 2012 3:45 pm
Use double flare only on brake lines. You can buy specific lengths of fitted tubing at parts stores and just bend it yourself.
Mon Apr 09, 2012 4:01 pm
Shawn - also, double flaring is an art. It's not easy to get consistent results without lots of practice.
I'd also do what Phil recommends, buy standard lengths at the parts store and make them work. Just make sure you get the right threads.
Mon Apr 09, 2012 4:57 pm
Cool. Thanks guys, I'll check into the parts store.
Mon Apr 09, 2012 8:09 pm
where do you live? i have a couple flaring tools and I just finished running my own fuel lines setup with double flares, but as others have said you can just get some lines from the auto store and bend them up.
Tue Apr 10, 2012 10:41 am
Thanks, I found some at the parts store that are pre flared and inexpensive. Sounds easier than doing it myself and having someone else fix it later!
Tue Apr 10, 2012 3:26 pm
Tue Apr 10, 2012 5:35 pm
33,172,837 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
