It is currently Mon Nov 25, 2024 6:24 pm
[ 9 posts ] |
valentino
5.0 has no go
I just compression tested my engine #1-70,2-70,3-80,4-90,5-90,6-95,7-90,8-95.the spark plugs looked good and i have a msd ignition in it,but it has no power.any suggestions?
Tue May 01, 2012 12:10 pm |
Re: 5.0 has no go
That is very low. Either the timing chain has stretched and jumped a tooth or that motor is just plain worn out.
Tue May 01, 2012 1:12 pm |
Re: 5.0 has no go
Did you open the throttle up all the way when you performed the compression test? I have seen numbers like that when someone forgot to open it all the way up.
Tue May 01, 2012 2:01 pm |
valentino
Re: 5.0 has no go
I didn't know that I'll try it again
Tue May 01, 2012 3:01 pm |
valentino
Re: 5.0 has no go
just did it with the throttle open and they went up twenty.so Number one is 90,2-90,3-100,4-110,5-110,6-115,7-110,8-115
Tue May 01, 2012 7:12 pm |
Re: 5.0 has no go
Check to see if you have spark, use instructions under "Magnetic Pick Up Trigger": http://www.msdignition.com/page.aspx?id=3206
Tue May 01, 2012 8:06 pm |
valentino
Re: 5.0 has no go
Just did the msd test and its working.
Wed May 02, 2012 1:28 pm |
Re: 5.0 has no go
Those comp numbers are still pretty low. Do you know the history behind the motor? Miles, cam, previous repair work done.
Wed May 02, 2012 3:07 pm |
valentino
Re: 5.0 has no go
no nothing in fact he told me it was a 351 lol
Thu May 03, 2012 11:14 am |
[ 9 posts ] |
Users browsing this forum: No registered users and 97 guests |
