www.ColoradoClassicBroncos.com - View topic - Moving Bronco - need a bit of help
It is currently Mon Nov 25, 2024 5:38 pm
Reply to topic  [ 19 posts ]
Post Moving Bronco - need a bit of help
So i made a deal with the devil and will be taking the truck into the blasters on thursday evening.
However as many of you know its a rolling chassis without brakes or steering and I will need to get it on a trailer of some kind to get it and all the parts to blastech. I haven't ruled out hiring a flatbed, however I do have access to a large pickup so was thinking of renting a uhaul trailer or borrowing one so i can get the bronco and all the pieces over to the blaster. whatever was the cheaper option.. believe me the blaster is only the beginning ;)
Anyway long story short would anyone be available on thursday sometime to help me load up the bronco to get it over to the blasters? I will have it ready to go by thursday noon, they are expecting it by close of business - i could do it fri as well however the forecast calls for rain..
shouldn't take too long.. maybe 30 min?
Mon May 07, 2012 10:44 am
Post Re: Moving Bronco - need a bit of help
We rented one of the car dollies to bring Drews home. Worked great and only cost $50. I dont know about my availability to help but thought I would toss that out for you.
If I am free when you are loading, I will be glad to come over and help.
Mon May 07, 2012 11:02 am
sounds good, i will have to see about keeping the rear brake lines off the ground and away from the pinon.. i could tie them up i guess.. but good idea on the dolly
Mon May 07, 2012 11:05 am
I should be available Thursday, when you get your plans locked down let me know.
Mon May 07, 2012 2:57 pm
I can break away from work to help - let me know.
Mon May 07, 2012 4:02 pm
cool deal let me see what i can do for transport, i will be working the next few nights to get the truck stripped down to a shell to be ready
Mon May 07, 2012 4:45 pm
Mon May 07, 2012 10:55 pm
looks like we are doing this at 2pm on thursday if anyone is around. Like i said shouldn't take too long but will probably need a bit of a hand to get it out of the garage and lined up with the trailer as obviously it has no brakes or steering wheel and i live on an incline/decline?
anyway if you can make it please PM me. My address is in the members section! Thanks!
Tue May 08, 2012 7:45 am
I should make it barring a bathroom remodel disaster.
Tue May 08, 2012 5:25 pm
Tue May 08, 2012 5:39 pm
Would one of you fine gentleman have an extra steering setup? the one i have is garbage.. I can't even get a castle nut on the TRE's and one of them doesn't even have a hole in it for a cotter pin.. not sure whats going on with them but the set iam trying to use sucks trying to get it secure enough to roll around on.. If not Iam sure i can figure something out..
Wed May 09, 2012 1:11 am
if you dont mind bringing it just in case.. I'm a bit out of thebronco fund at the moment and dont have enough steering ends to make a decent set.. Kirk is going to bring one as well just want to get the tires rollin
Wed May 09, 2012 8:48 am
I've also got a spare if Dan's doesn't work for some reason. It's shot, but it'll work for what you need.
Wed May 09, 2012 11:41 am
Wed May 09, 2012 11:57 am
ok iam about 95% ready to roll.. just taking the last few things of the dash and that should be it..
Thu May 10, 2012 12:33 am
Alley would be good. I will have the garage open and no car out back. See you at 2 pm
Thu May 10, 2012 8:03 am
Thanks Dan, Kirk and Chad for swinging by to help and hauling it around Denver.. bronco is off to the blasters then the body/paint shop!
Thu May 10, 2012 3:59 pm
Sweet! Nice to see that you were able to put things together to do everything now instead of down the road.
Thu May 10, 2012 4:46 pm
and you see the roll bar made it in the back.. still considering it thought why not since everything else was getting blasted...
Thu May 10, 2012 4:49 pm
Users browsing this forum: No registered users and 120 guests
33,079,497 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
