www.ColoradoClassicBroncos.com - View topic - Media Blast of Body / Engine Bay
It is currently Mon Nov 25, 2024 5:19 pm
Reply to topic  [ 15 posts ]
Post Media Blast of Body / Engine Bay
Anyone have a line on a vendor that will media blast the body / engine bay of my Bronco? I'm not going to do a frame off, but need to do more than just compound and wax. I will be repainting in the original colors. HELP!
Sun Apr 01, 2012 10:05 pm
Post Re: Media Blast of Body / Engine Bay
There is a really good guy over behind Fargos Pizza (on Juanita if I remember right) that does sand or media blasting. Last time I was there he had a rolling vehicle with the engine pulled and was doing everything.
Mon Apr 02, 2012 10:10 am
I am going to be taking my newly acquired Stroppe rims over there today to get media blasted. I am not even sure how the process works. Once media blasted do I get them powder coated and then painted the correct Wimbledon White or do I get them media blasted and then painted? I'm sure they will tell me -- but I was just wondering what everyone else does.
Fri May 11, 2012 9:37 am
talk to who ever is doing the blasting, they typically have someone that they will recommend to do any powder coating
Fri May 11, 2012 11:08 am
Gotcha. But do you normally powder coat wheels before painting them or are they just powder coated or just painted?
Fri May 11, 2012 11:25 am
Powder coating is (sort of) a kind of painting. The main difference is that the "paint" isn't carried in a solvent. The wheel will be given a slight electrostatic charge and then a powder is sprayed onto it. The static charge makes the powder stick. The wheel is then baked, melting the powder. Powder coating is tougher than paint in most circumstances, but may not be available in the exact color you're looking for. You don't have to paint over it although I suppose you could. They may be able to match the original white, otherwise I'd just prime and paint like normal.
Fri May 11, 2012 12:17 pm
I really like Platinum Powder Coating off Janitell road in the Springs. They media blasted a lot of stuff for me and do a great job at good price. Also had them blast/powder coat two tube bumpers for around $200.
Sun May 13, 2012 11:30 am
Mon May 14, 2012 9:00 am
I will, I will. The guy behind Fargo's doing the sandblasting said he has a couple of places he uses / recommends -- I can't remember the names off the top of my head, but when I pick up the rims I will get the names again and let you klnow. $15 a rim to sandblast -- is that an OK price? The guy was very nice, showed me around his shop, talked process, etc. He's got a bunch of old gas pumps he is restoring for his home garage.
Tue May 15, 2012 9:45 am
Doesn't sound too bad considering that it cost me about $60 to have a tailgate sandblasted from him.
Tue May 15, 2012 3:47 pm
Did you get your engine bay blasted?
Sun May 27, 2012 12:57 pm
No, I did not because I am thinking that I want to -- at least for now -- keep the truck original. I am going to compound and polish the paint, including the engine bay, and keep it that way for the forseeable future -- at least until I can do a frame off restoration.
Mon May 28, 2012 1:22 pm
That is a great idea...I've contemplated doing the same thing since I was able to bring back the original exterior color so well. Getting in all the nooks and crannies with a buffer and compound will be a pain though.
Mon May 28, 2012 2:59 pm
You should protect the numbers (a Denver Bronco thing) painted on the core support.
Mon May 28, 2012 3:30 pm
Oh, I certainly hear you there sir and agreed! I'll be sure to come up with some kind protect-o-plate or something. :-) BTW -- As of Friday the engine is up and running -- so it is time to mate it up with the transmission and get it in the 75DBE! Woo hoo! I am out of town this coming weekend, but I hope to work on it the following weekend. Finish getting the engine bay prepared, get motor mounts, busings installed, etc. LOTS of work to do!
Tue May 29, 2012 3:33 pm
Users browsing this forum: Google [Bot] and 50 guests
33,076,194 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
